Sneaky Pete
Where would be the best place to attach jackstays to and by what method. last boat I had they attached to the aluminium toe rail by D shackle next boat has a hardwood toe rail so none starter there.
depends on where the existing strong points are or where you can add some, but in my opinion, they should be as close the the centreline as possible, not on the side-deck. Mine are on the coach roof and start alongside the companionway hatch.Where would be the best place to attach jackstays to and by what method. last boat I had they attached to the aluminium toe rail by D shackle next boat has a hardwood toe rail so none starter there.
Don’t think that would work on our boat - and many. Essential to be able to clip on before leaving cockpit, so need rear connection point for jackstay on side deck near pushpit. Then would need to go forward and slightly outwards for 2-3m - which works if connected at pulpit and passing outside stays, but would need to be extremely loose if it were to curve back towards the mast in the next 3m or so.You can Y or V jackstays along centreline if you have sprayhood. Basically a single point fixing at base of mast ... leads aft in either one JS or a pair ...
I've seen on large boats ... most had more than one point in cockpit .. ie aft and one each side fwd ... the stays came back either side of hood and a dual hook line was able to clip on before unclipping from cockpit ...Don’t think that would work on our boat - and many. Essential to be able to clip on before leaving cockpit, so need rear connection point for jackstay on side deck near pushpit. Then would need to go forward and slightly outwards for 2-3m - which works if connected at pulpit and passing outside stays, but would need to be extremely loose if it were to curve back towards the mast in the next 3m or so.
Probably works in smaller / narrower boats and with small (or non existent) sprayhoods, but not as get bigger With a wide sprayhood.
But never had concern about using along windward side deck.
That's what I've done, 2x mast base to cockpit sides, flush to the spray hood. Bow one is central, hardly ever used.If its two stays running aft - they create a V - each fixed to either side of sprayhood.
Foredeck of course is single from mast to pulpit ... unrigged in port to allow forehatch to open ..
I would not completely write off the concept of a webbing jackstay running along the deck. As Dunedin pointed out, if you go forward on the windward side of the boat then the jackstay on the deck provides maximum protection on the assumption that you will not be swept off into the wind and waves. My sails are all hanked on, so I spend a lot of time on the foredeck putting in reefs etc but I don't think I have ever attempted to go forward on the lee side of the boat. The concept of clipping on and off with multiple tethers has no appeal whatsoever. I think it is best to clip on once from the cockpit and go forward with both hands free. One for the boat etc. I'm not saying my method would suit all boats, but it certainly suits my Vertue and probably many other small boats.
A suppose that is possible, but I'm happy to take that rare risk in preference to fumbling around with multiple clips. To me it would be like clipping on to every rung whilst climbing a ladder, it might help to save you from a fall but it could equally be the cause?Fair comment - but one wave rolling that boat and whether windward or not - you can be over ...
