petem
Apart from these ECUs and a gasket, are you aware of any other issues with VP not supplying parts for old engines?Well said .
Its what I see and hear around Italian marinas .Full support of old motors in old boats .
Bloke with Phantom 50 near me was incapacitated for 6 weeks inc the whole of August this year awaiting some fuel injector black box electrotwackery with his D12 s .Apart from these ECUs and a gasket, are you aware of any other issues with VP not supplying parts for old engines?
Gasket has been stopped since 2012. There was a post about it here. Volvo is supplying sealer which is a pain to make if someone is not used to it.Apart from these ECUs and a gasket, are you aware of any other issues with VP not supplying parts for old engines?
It beggars belief and is a reflection on the values of VP, that if they can’t make a profit on sourcing and storing an individual part (the gasket) then they drop it. There is a need to stand back and strategically look at the profitability of supplying a complete service.Gasket has been stopped since 2012.
I suspect it was because gasket sealant is perfectly fit for purpose. VolvoPaul and Spannerman don't have an issue with it. Perhaps it's because they know what they're doing (and are able to follow simple instructions) whereas others don't?It beggars belief and is a reflection on the values of VP, that if they can’t make a profit on sourcing and storing an individual part (the gasket) then they drop it. There is a need to stand back and strategically look at the profitability of supplying a complete service.
I think as long as you follow volvopaul and spannerman’s detailed instructions and not the simple instructions that others on here have done and failed, you’ll be ok. Not a great substitution for a tried and tested specified product.I suspect it was because gasket sealant is perfectly fit for purpose. VolvoPaul and Spannerman don't have an issue with it. Perhaps it's because they know what they're doing (and are able to follow simple instructions) whereas others don't?
I tend to think that companies do things for a reason. When VP stock thousands of other gaskets I suspect there's a valid reason for them not doing so in this case. Would be interesting to hear VP's side of the story.Not a great substitution for a tried and tested specified product.
Not really it’s still a crap system.Just trying to work out why they did it .Incidentally, I see that Porto was defending the gunk in the original thread....
(2) KAD 44 Rocker Gasket | YBW Forum
Is that the one we talked about that has 72Ps?...
Went to see a boat with a pair of very popular VP engines installed.
To suggest how well the boat had been looked after the broker offered reams of foolscap on lots of little jobs carried out very recently.
filters of course
new lift pumps
tank cut open and cleaned
fuel polished
relays cleaned
looms replaced
Felt sure the present owner would tell any prospective new owner about any possible ECU problem. ? Clang Clang went a warning bell
That’s the problem you want to see a file of gen service items sprinkled in with the odd timely rebuild .Say a water pump , shaft seal , or coolers .A troublesome boat , the boat just dies and shuts down mid journey, once between Majorca and Ibiza..
Sometimes virtually immediately sometimes it waits a while.
Want to get home ? , shut everything down and turn back on, this deletes the fault codes ? , limp back home again on one engine.
Start with the obvious.
Change filters etc and ensure all fuel lines are clean.
Still shutting down.
Change lift pumps
Cut inspection hatches in fuel tanks and steam clean.
check /clean relays
try hard wiring multi pin connectors.
still shutting down .
Rumours the ECU might be the problem ask local VP expert to take look.
try to find secondhand or recon unit anywhere in europe
try to buy new unit HOW MUCH...... and anyway no stock mate.
take unit back to UK for fixing/replacement/ reprogramming anything really to get a 200K boat running.
Finally give up and boat on market, seems OK on survey run out.
Info later that boat is still playing up .
filters of course
new lift pumps
fuel polished
relays cleaned
looms replaced
He put a massive amount of time and tactical bullying to get this far .It's a shame, but understandable, that Mike seems to have found an issue for his customer's boat and is no longer proactively chasing VP.
Things are even worse , no MDI units available for the D1 compact engines.That was speculation, not the official VP position. As VolvoPaul says, we don't actually know the current position. For all we know, the ECU's are now back in stock.
Whatever engines you run, there is the risk of components becoming obsolete.
In fact, even propellers can have a 2-3 month lead time which is enough to ruin anyone's season.
When doing this job it’s how you prepare the head face and valve cover , I’ve never had one leak yet from using a standard sealant from a motor factors, it’s how you do the job that counts .I suspect it was because gasket sealant is perfectly fit for purpose. VolvoPaul and Spannerman don't have an issue with it. Perhaps it's because they know what they're doing (and are able to follow simple instructions) whereas others don't?
75P ???? Wiring loom mod failed on crimped joints , this was a recall to stop it jumping into gear , cut off mod and start again.A troublesome boat , the boat just dies and shuts down mid journey, once between Majorca and Ibiza..
Change lift pumps
check /clean relays
filters of course
new lift pumps
fuel polished
relays cleaned
looms replaced
