CalicoJack
As previously mentioned our Neptunian ketch was hauled out with the intention of soda blasting and then cooper coating. Since then things have gone from bad to worse. The hull was covered in dozens of small blisters, the largest about the size of a small finger nail say 10mm long. A well respected surveyor was called and his meter showed that the readings were on the high side, but only just in the red scale, as opposed to the orange scale. Apparently we are lucky in so much as Tylers, the builders, used a clear gell coat below the water line, so that we can really see what is going on; I must say that it doesn't feel very lucky to me. There is in addition to the blisters wicking, which apparently shows how the moisture is travelling through the outer layer of fiberglass mat.
The surveyors advice was to get the problem dealt with sooner than later ie some time during 2014. The soda blasting has opened some of the bisters, but by no means all, although it could not go back in the water for the rest of the season without spending some money on filler, primer and anti-fouling. The other suggestion is to employ a professional to strip the gell coat, then let it dry and follow that by epoxying the hull.
Our problem is what to do? Are we just throwing money away by putting the boat back in the water and dealing with it in the autumn? Should we bite the bullet and go ahead and let the professionals deal with it; the down side being the cost and the fact that we will be without the boat for at least six months? Or is there some other cunning plan, that we don't recognise?
Your thoughts are much appreciated
