Suzi B
I was wondering if anyone could share general thoughts on planning a trip from the Solent to the firth of Clyde (well a bit further north but from the Clyde it's familiar territory). Obviously it's weather dependent and we'll make sure we have the necessary charts etc but I was hoping for thoughts on the big planning markers. For example our 'local' one is the Mull of Kintyre - you need to be in the right place at the right time and it's quite a long day and needs to be done in the right conditions. I know there are a few obvious candidates between the Solent and the Clyde but it's different seeing them on the map - I've love some thoughts, pointers, advice from those familiar with the areas so that I can be aware of the most challenging areas and plan around those.
For reference:
Crew of two, one experienced, one not (although not a total beginner), in a boat quite new to them so we'd be planning to sail where possible in daylight hours only. Departure probably in June so that should help.
We'd like to make the trip as quickly as possibly without compromising safety and at least a bit of enjoyment! The main thing in the first instance though will be to get the new boat back to within reach of home.
The boat has a shallow draft and can beach and the anchor is a good one and over specced for the boat.
We don't want to go into marinas as berthing is stressful! Mooring buoys are a bit better but we're much, much happier dropping anchor.
We'll have quite a lot of solar and a water maker so should be pretty self sufficient.
For reference:
