superheat6k
I changed the oil yesterday on my Port engine using a 12v change pump from Aldi / Lidl I bought a few years ago. So I thought, having successfully drained the oil in quite short order, and with no mess, I would use the pump to put the new oil in.
The end of the outlet tube has a small plastic nozzle to ensure a clean drip into the receptacle.
So suitably inserted this tube into the oil filler aperture in the rocker cover, I then pulled out the tube, which got slightly stuck so I lightly tugged it, and out it popped - WITHOUT THE SMALL END PIECE !
The wet & dry hoover didn't retrieve it so in the end I had to remove the rocker cover - not so easy on a Ford Sabre with ~ 2 - 3" clearance above the cover to the deck head above. one screw would have required extensive engine dismantling to get to, however I was able to gently prise the cover where the fitting had dropped in and was able to locate & retrieve it with some long nose pliers.
So two hours and an enormous amount of loud expletives later the fitting was removed and it is now in the bin as a completely unnecessary PITA device.
This exercise was accompanied by a change of the fuel filters. Before these were bone dry, and afterwards both drain caps started leaking, and in the end were replaced with some secondhand filters bases from the Chandlery Barge where my boat is based. This left the bilge with an annoying quantity of diesel that had to be soaked up with oil absorbing pads, then a through scrub with detergent where the fuel had managed to pray itself, not least from having to prime the system several times until I got the drains sealed.
So a 2 - 3 hour job became a 5 - 6 hour job due to completely unnecessary problems, and I still have the delightful Eau de Diesel aftershave scent stuck up my nose this morning !
