jordanbasset
Great thread, good to see the project developing, loving your pictures and posts
The BIG question now is WEST MARINE ?? or some other supplier? What’s the consensus on the forum for filler, gelcoat etc?
East coast fibreglass
+1. Much better prices for quantity. I understand that epoxy adheres better to old polyester.
I was under the same impression. I'm just going to have to see advantages /disad. price. thing.
Now we get a skip to dispose of the interior and as soon as that’s done we get a surveyor in for a first survey.
Are you spending money on a survey from choice or is there some need to have one done?
Was going to propose Reactive Resins as they had a fantastic range of great value quality products, but seem to have gone into liquidation(anyone know whether they are reincarnating?) . Matrix Composites are good for glass, cores etc.
Not personal observation, but others have suggested that the West resins are susceptible to "amine blush".
Check to see if the deck is squishy, especially around any screw holes etc. If not heavy enough yourself recruit an 18 stone friend to walk around on deck.
Delamination is something that occurs with osmosis, and while not being difficult to handle, I want to make sure we have none and if we do then address it as when we peel the hull for the osmosis treatment.
Other than wanting to know if the hull is sound before investing millions in the rest of the build, is there a need for a survey? You'll need another one to get insurance after the boat is completed anyway.
If it is a matter of looking for de-lamination just get a larger socket from your socket set and gently tap the hull in, say, a 3" grid yourself. Any de-lamination of the hull will be obvious.
You'll know the lower hull will be wet from all the water sitting inside, so no need to pay a surveyor to tell you that, but once dried inside it should dry out ok during the summer if you don't seal the water in.
If you do go for a survey, let the surveyor know it is a bare hull and deck and negotiate the price accordingly. Most surveys cover an awful lot more.
We spoke to one that is making a survey in 2 parts for us, a primary inspection of the hull, then when the build is finished a final inspection of the vessel prior to splashing. It’s an “acceptable” price for the all thing. We did check for referrals from a few people that used him before and were able to negotiate a “special” deal since its basically a bare hull to start with.
Of course getting a brand new hull might be cheaper than peeling the old one.![]()
My fear is that my vacuum pump (High Industrial Vacuum) (it evaporates water so fast by sublimation that the water freezes in a matter of minutes) will suck the hull through the pipes and I end up with a crushed hull the size of a pea.
