Tranona
Re: Update!
Amine blush is only really an issue if you are using the epoxy as a coating and then painting over and can be overcome by using peel ply. however, don't see the need for any epoxy coating in the sort of fitting out you are doing. Epoxy is useful in doing repairs on fully cured GRP when it is difficult to prep the old to ensure good adhesion of new polyester. However you are not in that position as although the hull is fully cured you should be able to grind back sufficiently to get a good key for tabbing in your new timber and ply. No need to coat ply internally with epoxy (or indeed in my view externally either) - conventional paints are more than adequate. Coating with epoxy has its place, particularly in construction methods like strip planking and cold moulding, but you are not doing either of these.
Matrix Composites sells some stuff that I like, still looking for a few more dont mind trying new stuff.
I have heard from the amine blush problem on moist environments, not something I can discount on account on how we are doing the boat. I think it can be solved with peel ply or hard grinded with diamond dicks but involves a bit of rubber grinding to de clog the disc. I rather avoid it if I can. Good point.
