Bouba
The railings and steps are a work of art ? ...is this all the original plans or did you go off the reservation ?More photos today of the stainless steel work. One of the things that you really have to get to grips with with welding, is how the metal distorts due to the welding, heat and contraction. Stainless seems to be particularly challenging in this respect and I have to say that many test pieces were completed and a few hours of YouTube watched prior to completing any work for real! For the handrailing, Tee joints are the worst! having Notched the end of the tube and placed it against another, if you then proceed to complete the weld without any other control of distortion, what was the straight section of tube will be bent like a banana following the weld! To counteract this, with ideas stolen from the internet and YouTube, I made the clamp shown in the first photo. This has a raised central nib such that when tightened onto the tube with the g-clamps, bends the tube in the opposite direction slightly. The clamp was then left in place whilst the weld was completed and when everything cools and the clamp is removed, hopefully you end up with a straight section of tube and a nice Tee joint. It was a case of learning through experience as to how much “counter bend pressure” to put into the tube prior to welding. This wasn’t required for the tack welds, just the final full welds.
After all the welding was completed, all the welds had a pickling acid applied to remove the weld tarnish which was then washed off and the welds polished using small 60mm buffing wheels in a drill.
Bouba - I think your question is answered in these photos!
View attachment 133262View attachment 133263View attachment 133264View attachment 133265View attachment 133266View attachment 133267View attachment 133268View attachment 133269View attachment 133271View attachment 133272
