Oily Rag
Can anyone recommend a good pump please? 12 volts for onboard use.
I have one of these which still works after 25 years, is very quick and delivers enough pressure not to need a hand pump to finish off. Rule LVM ID-20 High-Speed Inflator Deflator Air Pump 12v to me, it was certainly money well spent.Can anyone recommend a good pump please? 12 volts for onboard use.
That's exactly what I do. 60Ah LiFePO4 battery, bought for the dinghy motor but also useful for the pump.I wonder if an electric outboard battery could also power an inflator?
May I ask what size of dinghy you are inflating on how long it takes?i user this, charge lasts ages, has usb and light on it too. it inflates quickly and is light.
Air NRG 6000 rechargeable inflatable dinghy pump
Thanks Woozy. I am looking to replace a Bravo BST 12 HP and this may be an option though both the low and high pressure outputs are lower.and my dingy is a bit larger. I like the integrated battery - as long as it will do a full inflate and a bit of a deflate on one charge.
