gljnr1983
I find that the faster you are going when you set a delta the harder it is to get out of the sediment as i had to power out of some soft stuff a couple weeks ago,the soft stuff must have been mega deep tho.
Fluid dynamics says the drag from a concave surface is considerably higher than a convex one.
Soft mud is not an entirely fluid media, but its close. Combined with the larger blade area of the new generation anchors, the resistance of the blade area is concpsiderably higher than the older generation anchors in soft media.
But they'll still drag, albeit at a more modest rate! Better to anchor elsewhere ... ...
A couple of years ago I replaced a rusting 25lb Sowester Plough anchor (CQR copy) with a 10kg Delta. ......."
Just wondering if the 25lb plough and the 10kg Delta are the correct size for the boat in the first place. Anyway, I too reckon that a Delta does "plough", but if correctly sized for the boat and the conditions (wind and tide) is is being used in, then the expected drag can often be handled so as to not cause a problem. I'll guess that many purchasers buy the anchor size "recommended". But I seem to recall the max conditions for that "recommendation" is F5 or 6 in a sheltered bay! Just checked on the Lewmar web site and cannot see the basis for the recommendation stated anywhere.
My requirement for anchoring is for it to hold in a F7 in a bay (when there is a F8 out at sea), or F5 plus a strong tide running. This requirement is based on experiences when cruising in the English Channel, because I find that shelter in a nearby bay at anchor can be far safer than battling a tide or entrance in foul weather to windward to find buoy or being 6th out on a pontoon. With a suitable anchor, shallow draft, and a rock hopping chart it is surprising where safe havens can be found in the most dreadful weather.
In very soft bottoms, fairly shallow, and no swinging around risk, I too would use a Fortress, maybe even adjusted to increase the blade angle (not that i have ever done that myself).
As an experiment, on a windy night, try laying out two anchors of different types off the bow on either side (easier for multihull owners), and see which one the boat is straining to in the morning.
While not ruling out the possibility that some of the issues reported were due to the condition of the bottom, we dragged in a well known anchorage and dragged past several other annchored boats that did not seem to have any problems. I just get the impression that the delta can be a bit tempramental - particularly in heavy mud.
