Neeves
For murky water introducing a second or third 5 micron filter would be a good move - but buy one for under 'domestic' sink applications. To be really 'efficient' you would want tp pipe so as you can simply move from one to another clean the first and move back - but we did not add another filter - it was a 'nice' thing to do but we never got round to it.
Our water tanks were only 200l each, one under the cabin sole in each hull. Each tank could be isolated from the other and switch drawing from one to the other was simply 2 taps. We measured usage with a dip stick through an inspection hatch in the top of each tank. The only easy way to empty the tanks for cleaning was to pump the water out. The only time cleaning was necessary was after a summer in Tasmania where the tannins stained the tanks (and the water line of the hull).
Wet always kept one tank full and emptied the other to use the water. We then used the second tank and re-filled the first from the de sal unit. Theoretically we were always using new water.
We tried to run the de sal unit only when we were motoring or before we were going to motor as the amount of water we made was a real drain on batteries. I'm not sure which was most precious amps or litres.
but we were strict with both. (Electric cooking is a whole new ball game, needing that Lithium input).
Sailing was meant to be a simple pleasure, you, a like minded companion, some breeze and good weather + decent forecasts, a knowledge of basic navigation - its growing into a highly complex technical 'machine' demanding a high level of management. And I have not even included anchoring.
. It certainly keeps the brain active.
No complaints - simply an observation.
Jonathan
Jonathan
