ghostlymoron
Is it preferable to use fresh or salt water?
Evian. Non carbonated.
You may have been joking, but that's more or less what we do with a racing boat kept on a swinging mooring.
We take bottled water with us, and what doesn't get drunk is used to rinse cleats and blocks after the race.
Our cruising boat, we use a deck wash pump to hose off bird mess and the general grime.
When abundant fresh water is available, we wash the boat properly.
In between, we might wash with seawater and rinse with fresh.
The Dutch run very tight ships and barges,always neatly painted and rust kept at bay,bought on of their very small buckets that enable water to be drawn up from the canal without excessive weight but enough water to splash away dirt.Salt water is fine if the boat is caked with mud and you want to clear it but the trouble can be that the salt gets onto and into everywhere and gets taken inside, where it is definitely not wanted. If you go to Holland, you will see Dutch sailors always hosing down the boat after a sea sail, and athlough not always possible, it is not a bad habit.
We were told that washing our teak decks down with seawater would keep them clean and looking OK. It doesn't. A chemical blitz is required.
Yes, a small bucket is the way to go. They can bought in varying sizes at a builders' providers. A full size bucket is quite heavy to lift on deck from water level. ad if dropped into the water on a lanyard when under way will either tear your arms off or break. Also, in the unfortunate event of having to use a bucket to remove water from below decks,a smaller one is more manoeuverable in confined spaces, particularly if it has to be done in a hurry.The Dutch run very tight ships and barges,always neatly painted and rust kept at bay,bought on of their very small buckets that enable water to be drawn up from the canal without excessive weight but enough water to splash away dirt.
