ollie1977
Hi all
New boat owner here and on recently checking my saildrive oil level I noticed (to my horror) that it had emulsified to a mayonnaise consistency.
The seals on the saildrive were replaced 2 seasons ago and I'm pretty sure the water ingress is a result of my over filling the oil when the boat was on the hard during the winter (rookie mistake and one which I never intend to repeat...)
AND NOW MY QUESTION...
I am aware (from perusing related threads) that sea water can be sucked into the saildrive through over pressure when too much oil is present. Clearly I need to lift the boat and flush the oil but is it possible that the saildrive seals are npt compromised and I simply need to refill the saildrive with fresh oil to the correct level?
If not already apparent I'm desperately trying to find a fix that does not involve swapping the seals.
Thanks in advance for your thoughts.
Ps I tasted the oil and I could not detect a hint of salt in it (not sure much turns on this but thought it might be pertinent to share)
