Loopy
I always like learning from the experiences of others so I don't have to make all possible mistakes myself.
So we recently took our first overnight trip (21 hours, 120 miles). As this was a first for us and the forecast called for deteriorating conditions we engaged the services of a sailing school instructor to go with us as an instructor captain.
Forecast: At the time and place of departure called for conditions to be in the mid force 3 range, with some slight weakening late in the day and strengthing to force 4 about 3 hours before sunrise. Winds were forecast to be from the SSE with a swing to the SSW later in the forecast period. This change of direction never materialized, forecast wind strengths decreased as forecast and then increased to force 5 by the time of our arrival with the occasional higher gusts, though this happened late enough in the trip that the seas did not really have much time to build past about 5 feet.
We had the autopilot on and steering for the entire trip. Initially, we began the trip with full main and no headsail on a 310 course, and the main on a preventer secured to the starboard side of the boat. We were doing around 5-6 knots on a boat with a hull speed of 7.5 knots. As evening approached, we reached a waypoint that required a 25 degree turn to starboard, so we undid the preventer and gybed and now ran on a starboard tack on a very deep broad reach.
Mistake #1: Not re-rigging the preventer after our turn.
We did not accidentally gybe, but i ended up sheeting the mainsail in tight to reduce boom travel if we had. Still the initial part of the overnight sail was reasonably comfortable. Winds had decreased enough that we motorsailed for about 6 hours.
Mistake #2: Letting the sun set with a full main hoisted and a deteriorating forecast.
Around 2am the winds started to build significantly and 3am we began to see boat speeds approaching hull speed on main only. We woke up our pro to get some additional advice. He recommended we turn into the wind and attempt to reef the mainsail - particularly given the starboard turn at the next waypoint that would bring us onto a beam reach.
So we turned into the wind, now pounding into roughly five foot seas. He abandoned the idea to raise a reefed main and recommended we continue on our roller furling Genoa only as we could reduce that sail easily when sailing downwind and we would not run the risk of an accidental gybe on an unprevented main.
So we dropped the main and unrolled the genoa and continued on our way. The ride seemed to deteriorate dramatically with this strategy with port and starboard yawing +/- 20 degrees bringing the apparent wind from our stern to almost a beam reach at times. A few hours before morning, we noticed the boat wallowing in the troughs with a decrease in boat speed to the mid 4.5 knot range, with accelerations to the 9-12 knot range surfing down waves.
Fortunately as the wind and seas were all from the same direction we had no significant breaking waves to contend with.
We reduced our genoa, reached our next waypoint and turned to starboard, now running on a beam reach to destination. This reduced our yaw, but increased roll as we took the larger seas on the beam. After entering the bay we turned into the wind, doused the sails, and motored to destination.
I had been up 24 hours straight not wanting to leave my wife on watch alone and so asked pro to take us into the channel. He promptly not only ignored the channel markers, but also the bread crumbs on the chartplotter display (which I specifically told him about and asked him to follow) indicating our previous successful exit from the channel and tracked the charted channel inbound. Touched bottom, did not ground hard. Frankly, this sort of rookie mistake - which even I know not to do - surprised me from someone who had the stated experience he had.
So. What should we have done differently? Set the third reef in the main and continue on main and headsail at sunset so we could easily reduce sail area by furling the headsail on the roller as we proceeded downwind? Should we have set a preventer for the starboard tack we were on given the forecast wind shift that never materialized? If the wind had shifted and we had a preventer set we would have had to undo it as a further turn to starboard would have turned us into the shoreline. Advice to reduce yawing which seems to be not only a particularly uncomfortable motion but somewhat risky given the large shifts in apparent wind and risk of accidental gybes? The autopilot has a track hold and a wind hold mode. The former lets it track the magenta line, and that is the mode we operated it throughout. Would it have been a wiser plan to run it in wind hold mode making it work (I'm assuming) like a wind vane? Or given the degree to which the sea state was changing the apparent wind would that have made things worse?
I'm a commercial pilot, and the boat's motion downwind under headsail alone seemed very much like a dutch roll (https://en.wikipedia.org/wiki/Dutch_roll) which in an aircraft of course is something to be avoided at all costs lest you enter a realm of negative stability and suffer an upset. Aircraft actually have redundant computerized yaw dampers to prevent this. I would like to think that this concept of negative stability is less relevant in a keelboat, but the existence of a capsize screening formula makes me wonder.
This seems to be the catch 22 of sailing that no amount of fair weather practice can prepare you for: You don't know what to do when conditions deteriorate until you are out in said conditions without knowing what to do in them.
An early 90s design, 12'8" at the beam, carries more of that aft than the extreme IOR boats but not as much as a modern design. Here she is by the numbers:
38', 32' LWL
S.A./Disp.: 16.46
Bal./Disp.: 34.35
Disp./Len.: 193.09
Comfort Ratio: 21.90
Capsize Screening Formula: 2.11
I think she's a good, solid boat I'm just not sure of the best way to keep her in the envelope so that she - and we - are equally happy.
38', 32' LWL
S.A./Disp.: 16.46
Bal./Disp.: 34.35
Disp./Len.: 193.09
