Bouba
Like all of us paranoid boaters.... I check constantly....and will be there this afternoonHave you been to the boat today ?
Just asking ....................![]()
Ist OK he's got goggles and snorkel...Hey Boat - where art thou ??![]()
Now you know for sure that the home made spanners couldn't undo the seacock and what a pig of a job it was doing all of the grinding and cutting, risking turning the through hull and/or damaging the threads, would you concede that it would have been easier and quicker to have simply ground the out flange off and just unscrewed the whole assembly from inside ?I think writing this ‘saga’ up took longer than the actual events…and reading some of the comments was certainly more traumatic![]()
This has been a very enjoyable read. Let's hope the op. didn't over do it with the 291inside the valve ( female thread) and block up the fitting. Seen that done many times ( semi ret. gas engineer) with countless number of years handling cocks of various sizes. Ohhh Ehrrrr Matron !!!!!
Thank you Paul and Fr Hackett…I will say this once (although readers will note I have said it fifty times already)…I tried to do the job as quickly and cheaply as possible…this meant only having the boat in the slings not a cradle and using as few ready available parts as possible and doing it without an assistant….with the backup plan that the boat could be put on a cradle next morning, that I could source the parts that I could find an assistant that I could wait an extra day or so for the sealant to cure ….and I had a further back plan of calling in a professional (WHOM I HAD ALREADY CONTACTED).Now you know for sure that the home made spanners couldn't undo the seacock and what a pig of a job it was doing all of the grinding and cutting, risking turning the through hull and/or damaging the threads, would you concede that it would have been easier and quicker to have simply ground the out flange off and just unscrewed the whole assembly from inside ?
I only put the 291i on the male parts…although I did liberally apply them…I also thought that the silicone could travel…so far it is good (touch wood) in retrospect I would now choose plumbers tape which I had but was in two mindsThis has been a very enjoyable read. Let's hope the op. didn't over do it with the 291inside the valve ( female thread) and block up the fitting. Seen that done many times ( semi ret. gas engineer) with countless number of years handling cocks of various sizes. Ohhh Ehrrrr Matron !!!!!
About what i expected.Thank you Paul and Fr Hackett…I will say this once (although readers will note I have said it fifty times already)…I tried to do the job as quickly and cheaply as possible…this meant only having the boat in the slings not a cradle and using as few ready available parts as possible and doing it without an assistant….with the backup plan that the boat could be put on a cradle next morning, that I could source the parts that I could find an assistant that I could wait an extra day or so for the sealant to cure ….and I had a further back plan of calling in a professional (WHOM I HAD ALREADY CONTACTED).
As it turned out everything went to plan…except the weather window that I was hoping to take advantage of had closed…such is our boating life.
And I admit I only had one wrench in my workshop capable of 70mm…for that I am ashamed…so I manufactured some and they were useful. But no, as explained, I didn’t have the room in the bilge to get the necessary leverage
Bit harsh to call Bouba a prat, annoying yesI congratulate you Bouba on not only resolving this but also your civility in the face of a lot of posters talking to you in an incredibly disrespectful manner. I’m not sure how you’ve bitten your tongue and am unsure where having some knowledge of marine mechanics gives the right to act like a prat.
No…go back and re readI’m sorry to say that I lost the plot somewhere along the line. Am I right in thinking that, long story short, you ground out the old thru-hull, replaced same using appropriate sealant, attached the new valve plus existing pipework; that the boat has been re-launched and floats happily with no leaks?
If so: very well done. Must be time to enjoy actually using the boat again.![]()
Nah, short version: Ignoring good advice he attempted to unscrew the valve with his "fabricated" implements and failed, then proceeded to attack the valve with an angle grinder in the process damaging the threads of the through hull which he was lucky enough to be able to shorten. Then as luck would have it having not purchased a new through hull that definitely matched the valve ( as advised) nor did he check and measure the threads, he found that the valve fitted which he secured with copious amounts of 291.I’m sorry to say that I lost the plot somewhere along the line. Am I right in thinking that, long story short, you ground out the old thru-hull, replaced same using appropriate sealant, attached the new valve plus existing pipework; that the boat has been re-launched and floats happily with no leaks?
I know you are only here to troll...but I shall humor you.....the reason jobs take so long to DIY is that on a boat (do you remember what one of those is ?) everything is cramped and awkward....and at my age I simply cannot get in some of those positions...and those that I can, only for a few minutes and often not that long....and in between I need lots of rest time for the body to recuperate....I made two spanners for the task...one proved very effective and the other not so...but neither failed....because I made them. Cutting was always an option....there is limited room for a long enough lever....why do you think I had all my cutting equipment with me ?Nah, short version: Ignoring good advice he attempted to unscrew the valve with his "fabricated" implements and failed, then proceeded to attack the valve with an angle grinder in the process damaging the threads of the through hull which he was lucky enough to be able to shorten. Then as luck would have it having not purchased a new through hull that definitely matched the valve ( as advised) nor did he check and measure the threads, he found that the valve fitted which he secured with copious amounts of 291.
This one hour job took him an evening and night and some of the early morning to achieve. However he is happy having demonstrated at least to himself and long suffering wife that he could in fact complete basic maintenance tasks without sinking their boat.![]()
No...it looks exactly like it did before....except the floor is still covered with a fine gold dust from the cutting...I must clean it soonAny pics of the new valve in situ ?
