mil1194
This has all the hallmarks of fueltankgate again
Every single hallmark possible…..
![Man tipping hand :man_tipping_hand: 💁♂️](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f481-2642.png)
Disappointment?!?This is the biggest disappointment in the thread so far. I spend my life correcting my daughter on this and now JFM does it, a man demonstrably more successful than me.
It must be sealed or diesel would run out.Should the hole have been treated to coat of epoxy to seal the internal core?
No the hull…opening where the seacock goesIt must be sealed or diesel would run out.
It's a Beneteau so probably not.No the hull…opening where the seacock goes
Well at least his tool was not a Snap-OnGood news and well done if all OK.
Why is it called a Sea cock
More probably a snap offWell at least his tool was not a Snap-On
Let him sleep…he’ll never sleep well onboard again until it’s changed proper. Nothing worse than soggy pyjamasHas there been a review of the outcome or is he still asleep?
Self inflicted or notLet him sleep…he’ll never sleep well onboard again until it’s changed proper. Nothing worse than soggy pyjamas
Of course it’s not a Snap-On..,they are guaranteed for lifeWell at least his tool was not a Snap-On
The Beneteau do use balsa core…but they are an encapsulated core. The hull is made of thousands of small balsa blocks…each has fibreglass infused all around…so no single block can infect its neighbour. A two inch hole, at its mathematical worse can probably only penetrate four blocksWhat did you exactly do in the end ?
If you managed to only change the valve and the TTHF moved inadvertently or un noticed though you may not see a leak visibly inside it might be leaking from the outside ( sea ) skin into the balsa core of your boat .The balsa absorbing water first ….hence inside it appears ok .
That’s why , or a double reason with a cored Benny the consensus on this thread was change the whole lot ….so you can ensure the integrity of the outer skin fitting seal , and re gunk up the whole thing as passed through the hull layers .
There’s also my earlier point about various dissimilar metals ( new valve and old bits now either end ) = bi metallic corrosion acceleration and possibly bonding to address this .
Just saying .
