kalanka
Volvo 2003, freshwater cooled in Sadler 34
Whilst on passage off Canna overheating alarm went off. Cleared some weed from water intake. Not cured. Checked impeller - it had lost a blade - replaced. Looked carefully for this fragment but not found. But raw water flow is now good.
Problem persisted. Back to mooring under sail alone.
Engine overheats to 100 degrees after 8-10 min running under modest load (2000 rpm in reverse on mooring. It is real overheating - not just an instrument problem.
Have checked everything I can think of:
Sea cock/inlet fine.
Strong flow of raw water through system
Heat exchanger dismantled - no damage, corrosion or obstruction
Freshwater in and out on HE are different temperatures
Injection elbow removed - heavily clogged up and corroded - replaced with new item
Circulation pump dismantled, checked - all seems fine
Freshwater system drained and treated with Radflush and Fernox - little effect, very little grot flushed out
Temp gauge checked against lab thermometer - spot on
All accessible pipes are clear and in good shape
Thermostat replaced with new item
Ran without thermostat - still overheating
Am currently attempting to eliminate possible air locks in freshwater system - have already removed calorifier from circuit with this purpose - no effect.
Oil clean and at level - no water in it. Old oil drained - no mayonnaise etc
No gas, fumes or muck in header tank
Engine starts well, runs smoothly, nothing unusual until it gets hot
Belt tension fine
Overheating unchanged after all this. I am beginning to fear some serious blockage in head or block. If so is there any cure for this? Any reliable diagnosis?
Anything else to investigate?
Is it new engine time?
Your suggestions would be welcome.....
Belt tension fine
