Trident
Water pump works and pumps - as does the new one I just changed it to - but it builds pressure so that there is a good flow for a few seconds when the tap opens but then runs to a trickle . Close the tap pressure builds again so a good flow for a few seconds and then a dribble ..
I've changed the pump, checked the tank vent is clear, opened the tank inspection hatch for more venting, checked pipes for blockage, kinks etc, no leaks , pump is 40psi Jabsco, brand new , only has to lift maybe 50cm above the tank and 1.5m total length from tank. I've opened all taps in case of airlocks and all flow water - just very very slowly .
System is tank, strainer, pump, output to three taps for cold and three taps for hot via a 10L calorifier - the rate of flow is the same for hot and cold
I just can't think of anything else to check - any ideas please?
