Sea Change
Calling the geeks...
I believe it's possible to send and receive NMEA days over WiFi. But I'm pretty clueless about what's possible and how it's done.
I've got a bit of a mixture of instruments onboard:
ONWA 7" plotter with AIS (NMEA 0183)
Raymarine ST6002 autopilot (NMEA 0183)
Newer Raymarine depth and wind instruments, both NMEA 2000.
I also have a complete replacement autopilot system which is NMEA 2000, which I will fit at some point in the future.
What I want to achieve is:
- a better screen for chart plotting at the helm (the ONWA is very clunky, and is down below), running Navionics or similar, and ideally with AIS data overlaid.
- ability to view wind data down before, and ideally from mobile devices too
- ability to control the autopilot remotely would be nice
If it's possible/sensible/affordable, I'm thinking about getting a decent quality android tablet to use as a sort of MFD. It would live at the helm most of the time, but could be moved to wherever was convenient (e.g. under the sprayhood, or down below). It could be used as a plotter and also display wind, and control the autopilot.
Individual crew should be able to access data on their phones whilst onboard (so that the skipper can open one eye and glance at the wind data, without having to fully wake up).
I realise that needing to display data from both 0183 and 2000 systems will likely complicate things.
I'm aware that you can buy WiFi gateways,dongles, routers, etc, but have little idea of what these words mean.
Any suggestions or advice appreciated
