rajjes
It finally happened!
Due to complacency and carelessness from my side I fear I may have ruined my Beta 43HP (BV1903) which so far was running as sweetly as ever over these last 8 years of ownership! Eager to go sailing on a glorious day, I went out without doing any checks on the engine....(still kicking myself!). Motored out of the marina, sails up and had a great sail up and down the coast.
Returning back, I lowered sails and switched on the engine again to give it some use after a few weeks laying idle. After perhaps 10 minutes I heard the engine doing a slight knocking (tapping?) sound and looking at the instruments I saw the oil pressure light on! For some reason the buzzer did not work and I do not know how long the lights had been on.
I immediately switched off the engine and on checking the engine to my horror I found that the oil filter was leaking oil from a rusty spot which had developed without me noticing. I topped the engine with around 2 liters oil I had at hand and sailed back to the marina. I still had to motor (very slowly) the last few minutes to tie to the pontoon and the oil light came on again
I have now cleaned up the mess of oil in the bilges (collected almost the full capacity of 9.5 liters!) and serviced the engine with new oil and filters.
At least the engine is starting immediately but the tapping sound is persisting. The flywheel has very little (<1mm) fore and aft play but I do not know if this was there before or if indeed normal. I am now waiting for a mechanic to come and check it out, but would like any opinions on what to expect to brace myself?
For sure a LOT of lessons learnt on not taking the engine for granted!
