vas
Yes, I ran that calc.
I also read the Victron MPPT manual.
I may have said this before but there is a small catch when using a small number of panels.
The Victron MPPT controller requires that the panels generate at least 5 volts more the battery voltage before the MPPT controller starts.
After that, it only needs 1 volt more than the battery voltage to keep going.
In my case, (24v bank) the voltage could be as high as 28v after the initial charge from the generator and I would want the solar panels to continue charging the final (say) 20%.
The LG panels have a Vmpp of 33.2 volts which is too close to the battery voltage for the MPPT to start (28v + 5v = 33v)
So, if I'm to use 2 panels, they will HAVE to be is series to get a total Vmpp of 66.4 volts (and thankfully within the operating voltage of the Victron MPPT)
yes, you have mentioned it but I thought we should be OK as I was only considering 24V and not what the batteries may have at the time, indeed close to 28V!
Furthermore, considering that you'd like to take advantage of all the sun even when it's at an angle to the panels, which WILL be for much longer than a proper land installation (and I'm not even thinking about the sun tracking systems used in many parks...) it means that for most of the working day the panels wont be giving out that 33V (me thinks!).
So Serial connection is the only way making more important the proper matching of panels (was thinking maybe 2X280 plus 1X200 across at the forward section of the hardtop, which I wont bother now)
cheers
V.
