Hurricane
I know I've read of physical failures recently, have just done some brief searching and failed to turn up much though. It's possible it was on the cruisers forum, but I genuinely thought it was on YBW, my memory is perhaps not what it used to be.
Output loss via shading is something that any boating application is likely to suffer from I guess, but plenty of people use them successfully despite the inevitable losses.
You are not mistaken.
I also found some evidence that there were failures of semi flexible panels after a couple of years.
That initially put me off using them and at LIBS I approached that particular stand with the aim of installing rigid panels.
That company sells both and their prices are more on a domestic scale rather than that of most marine "rip of" companies.
So they didn't have a "axe to grind" so to speak.
I was very much "won over" by the salesman, so much so that I think it is worth a try.
In fact, it wasn't the salesman - I also spoke to an engineer who explained the manufacturing process.
They definitely won my confidence.
Lets see - I still have to get the final dimensions and compare the space that I have with the panel brochure/data sheet.
