Ian_Edwards
Hi, I have a Victron Energy MultiPlus 12/3000/120-50 230V, which works OK, except I don't seem to get the Mulltiplus to feed the mains through when the inverter is off.
When I turn the invert off, I hear the relay click, disconnecting the AC.
I'm fairly sure that the Multiplus can be programmed to leave the AC connected, but I can't see anything about that in the installation manual:
https://www.bmstechnologies.co.uk/w...01/Victron-Energy-MultiPlus-3000VA-Manual.pdf
I have the VE interface which allows the Multiplus to be programmed from PC, but I've only used that once when I first installed the system.
When the boat is ashore, it's often convenient to leave the AC on, but have the battery charger switched off, because the LiFePO4 battery are already at 80%.
Can any one point to the instruction on how to do this?
