RAI
Has any one received an official requirement to modify their VHF radios to comply with new channel allocations? Or is it just Belgium?
Yep, I got an official letter from BIPT requesting me to have my radio reprogrammed. I did not get the impression that it was just a Belgian regulation, but did not delve deeper into it. We have a year to comply
We are in a parallel universe ?I suspect the UK is a little bit behind
ITU world radio conference happens later this year, so expect to see some changes, especially in little used frequencies with wide area coverage.I think the ITU uses a "use it or loose it" attitude to spectrum. So those now rarely used maritime duplex channels are up for grabs, if maritime doesn't use it for more modern communications. Even then, they might have to share it.
I also learn that channel 31 can be added to your VHF radio, for Dutch and Belgian marinas.
For a UK registered VHF you require a Licence Derogation for CH31, with the proviso it must not be used in UK territorial waters as CH31 is used by Coastguard on beach rescues.
Yes, the spectrum wars continue to argue over a limited resource that can make some exceedingly rich.ITU world radio conference happens later this year, so expect to see some changes, especially in little used frequencies with wide area coverage.
That's interesting. My Belgian registered radios have no channel 31, but will now get it for marina chat. Still using ch9 for that in Spain.For a UK registered VHF you require a Licence Derogation for CH31, with the proviso it must not be used in UK territorial waters as CH31 is used by Coastguard on beach rescues.
