Soltron
chas
5 Aug 2001
West Country
A couple of weeks ago, I was gently guided towards Soltron when I posted a question about Diesel Bugs. I had a large plastic lemonade bottle of diesel that I had taken out of the drain plug of my tank. Even after the sediment had settled, it remained very cloudy. I put the remains of my Solton bottle in it (about half a teaspoon). 10 days later, it is as clear as diluted Ribena and about a third of the sludge at the bottom seems to have disappeared.
It looks as if the stuff might work!
byron
RIP
UK -Berks
Chas you will find that in the MotorBoats Forum the word "Soltron" is never used, people write "S*****N" instead.
Its a long story why but suffice it to say people are fed up with the debates on the stuff. The concensus is however that it is an OK product.
ô¿ô
Chris_Stannard
11 Jan 2002
Cowes. Isle of Wight
It may kill the virus but be careful that you don' t get the remains in your fuel pump and injectors. Suggest you change your fuel filter, though I do not know if they are fine enough to make the difference. Change it again in about 10 hours to make sure. If that one looks foul continue until you get a cleraan filter after 10 hours.
I repeat advice from elsewhere and personal experience, if you have a means of draining the water (condensate) from the bottom of your tank it pays to do it on a regular basis. This both stops the corrocsion of the bottom of the tank and denies the virus the place where they breed (the interface between diesel and water).
Chris Stannard
chas
5 Aug 2001
West Country
Thanks - I might try putting the bottle contents through a fine filter and see what I get left with
byron
RIP
UK -Berks
Naaah! can't get me with the simple sailor bit, you guys have to be able to navigate in zig-zags which is far more complicated than us stinkies going in straight lines ;)
ô¿ô
davel
30 May 2001
Hants/Berks border
I'd be grateful if you could do and post your results here. I've just bought a competing product which says it does the same as S******N. Plan to put some in my tank this weekend as an insurance policy. Boat launches tomorrow and I had problems with condensation 2 years ago after the winter lay-up.
Dave L.
DepSol
6 Oct 2001
Guernsey
It eats up the remains of the bug to a very small particle which passes thru your filters and gets burnt up so need to muck around just dose your tanks every time you fill up and never worry about bugs sludge or any other contaminates. Watch your economy increase and your emissions decrease, simple innit.
Dom
DepSol
6 Oct 2001
Guernsey
Whats the product calle and how much does it cost also dosage please.
Dom
davel
30 May 2001
Hants/Berks border
It's called Fuel Set.
Cost was £8.95 for 250 ml (Treats 1000 litres)
£16.95 for 500 ml (Treats 1000 litres)
£26.95 for 1 litre (Treats 4000 litres)
Claims as follows:
Contains no hydrocarbons, nitrogen or metallic ingredients. Fuel Set removes the moisture that fungi need to survive. Totally removes water from fuel systems, kills and disolves the diesel bug, treats all fuels, restores lost economy and improves performance, removes contaminates such as waxes, gums and carbon.
Dave L.
DepSol
6 Oct 2001
Guernsey
Yep know it well, it is good but doesnt work as fast or as efficiently as Soltron but is still a good product one the less.
Dom
chippie
21 Aug 2001
Northland New Zealand
Re: Davel
I dont get it. If 250ml treats 1000 litres does the 500ml bottle contain a diluted product as it too treats 1000 litres?
The one litre bottle obviously has the same concentration as the 250ml bottle as it treats four times the amount.
Please forgive me if I am being pedantic and it is just a simple typing error.;-)
davel
30 May 2001
Hants/Berks border
Re: Davel
Your pedantism is forgiven since your also absolutely right!
Oops, sorry, this was a typo, as you surmised it should have read 2000 lites per 500 ml.
Dave L.
davel
30 May 2001
Hants/Berks border
Dom,
Phew, thank goodness for that !
I bought it 'cos it was easily available. It's still a mystery to why it's so hard to find S*****N given that it's so good.
Dave L.
DepSol
6 Oct 2001
Guernsey
Hopefully Soltron will be more readily available in the near future for all you guys and if it is not I will make arrangements for anyone who wants it to be able to get it easily via me if need be.
Dom
