Ray Marine, Anatoly and Hey Kim have you seen this
aod
25 Nov 2002
Gosport
As always Kim that's a fair response to the post Hey Kim! have you seen the post by Anatoly.
Possibly in the poor angry blokes defence and not really understanding what he's on about I felt I ought to point out my own experiences with Ray Marine which may or may not be related to his issues.
I think Ray Marine after sales is about as good as it gets but there again it has to be.
One speaks as one finds and I have to have my Ray Marine instruments repaired (one or more of the seven in the cockpit) at least twice a year. I have a mixture of the older ST50 stuff and the much newer ST60 stuff. The compass gets fixed then the wind goes wrong, the wind gets fixed and the multi goes wrong!
Every single problem I have is with water ingress. I have of course taken all reasonable steps to seal the units myself like taping around the seams, covering the screw holes etc but non of it really works.
I bombed out on this years AZAB as a single handed entry because the ST4000+ control head corroded. It had been tested two weeks prior to the event and given a clean bill of health and whilst I accept that it was pretty wet and windy early June, these instruments should if nothing else be waterproof and they are simply not. Indeed they are not even weather proof!
More fool me for not taking a backup control unit but there again, even the thought of having to take backup units to cover corrosion due to water ingress on a sailing yacht is a joke.
If Ray Marine know they have problems with water ingress (as they clearly do) what on earth prevents them from sealing the PCBs with a few microns of clear plastic spray on coating? Absolutely nothing, unless you factor in that after sales service and spares (like Volvo engines) forms an intergral and essential part of the profit segment of their business case.
Hence excellent after sales!
In other words they build to fail in order to profit, and whilst that very common business strategy is not quite as critical when considering your TV it is on a yachts instrumentation purely due to the danger imposed when sailing blind.
A few years ago I sent every one of my seven ST50s to Ray Marine for checking and specificaly asked them to seal the units to prevent water ingress. Two weeks later I sailed over for Cork week on a bumpy wet day and every single instrument other than the Garmin GPS failed due to water ingress. Sure enough when they dried a few hours later they came on again but I knew................you know, and ............................Ray Marine know...................... that the PCBs would all subsiquently corrode warranting significant expenditure on new PCBs which in time would also fail. They did fail and they were replaced and they failed again...................all for the same reason 'Corrosion due to Water Ingress'
I simply haven't heard the same common complaint about any other manufacturers yacht instruments regardless of purchase price.
Personaly I would need some pretty potent persuasion before I ever bought another Ray Marine product and as they fail I will replace them with new units produced by a different manufacturer.
Funnily enough during this last Fastnet the wind has failed again but rather than go for the short terms cheaper option of replacing the PCB (for the fourth time) I will spend a little extra and buy a quality instrument that affords a greater reliability and longevity.
That purchase will certainly not be a Ray Marine product.
Also later this year I am project managing the fitting out of a brand new yacht and for all the above reasons I have already persuaded the owner to steer well clear of Ray Marine products. These days many companies opt for short term profitability because it pleases their share holders but in the longer term their business suffers and they go insolvent before being bought out by a new company who re-badges the old products, opts for the same marketing strategy, and follows the same pattern.
Into the hat goes Raytheon............abracadabra.................and Hey Presto we have.............................Ray Marine!
Fabulous re-branding...................fabulous marketing....................same crap product!
Richard
ThomasHome
11 Sep 2002
Kent
To be fair to Raymarine
................ I met a chap who was fixing his Raytheon plotter, we tested the unit on my boat and put the fault down to the sea talk receiver. The unit was quite old but I knew that Raymarine had a good customer service reputation and that they'd probably fix it for free. He rang Raymarine and they sent him a new Raystar 120 free of charge, these thing cost about £250. May be it shouldn't have gone in the first place but the after sales it pretty good.
Chris_Robb
15 Jun 2001
Haslemere/ Leros
I Think I'm lucky. However I do have a covered wheelhouse - after 6 years the ST50 stuff is great - execpt the water temp is minus 30 degrees! Everyone else I know has had water ingress with cockpit based intruments. shame as they are very good and clear instruments.
steve28
19 May 2003
Cornwall
www.falmouthgypsy.com
assuming the instruments last for the warranty period, do what i did and strip the pcbs out ,covers any tactile switches and contact areas and then spray with a plastic sealer spray which costs no more than a fiver.
they can be dunked in water then !
i do know the displays would need drying out and that the point is that water shouldnt get in there in the first place.
Gunfleet
1 Jan 2002
Orwell
I think we might be on a crossed line Chris. Because people complain the cockpit instruments get wet and let water in. Mine get wet and don't let the water in. That's all.
tome
28 Mar 2002
kprick
www.google.co.uk
As a matter of interest Garmin purge the air out of their receivers and fill them with a nitrogen mixture to prevent condensation. Why Raymarine cannot do this is a mystery to me...
Chris_Robb
15 Jun 2001
Haslemere/ Leros
Just being facetious (oh god - how do you spell it) 'cause I know the B&G don't let the water in!
Seriously though - I am the only person I know who hasn't had problems with the ST50, only because they are undercover. I did have a small problem with the sea temp in the first year - it read 15C when it should have been 17C so I never went swimming. Spoke to them about it, and then by next year it was showing 8C - they didn't want to know. so now I never go swimming on the grounds that its too cold
AlanPound
18 Jan 2002
Milton Keynes UK
B&G reputedly do the same (fill with Nitrogen), although their stuff is not 100% immune from problems of this kind, the stuff I have hasn't been overly irritating...
... just the one incident where I had to send a unit back to the factory for a rebuild -
B&G said -"yes, the problem is that it got water in it, but it can't our fault, because it is waterproof"... (difficult to argue with that sort of logic.....)
Alan
Clive
2 Sep 2003
Surrey England
I have just taken my ST50 wind, log & depth back to the factory for repair after getting water in them. it is costing me £420, yes four hunfred and twenty pounds, to get them fixed
<hr width=100% size=1>Clive
Sybarite
7 Dec 2002
France
After 10 years service my Autohelm 1000 gave up the ghost. I replaced it with an ST 2000 less than two years ago and I don't believe in that time I have used it more than a dozen times. It stopped on me and I opened it - the first time it was opened - and it was a mass of rust inside.... I took it back to the Raymaraine agent who before he would accept asked me to acknowledge that it was out of warranty..
(They may learn something though about French consumer protection laws..!!)
John
Ivy
20 May 2003
Bournemouth, England
If Ray Marine did fill their units with any kind of gas it would leak out through the same hole that lets the water in.
I bought the Silva Sea Data log / echo sounder two years ago, and the wind instrument last year. They don't let water in. (yet)
MainlySteam
24 Jul 2003
Chris seem like you and I are a club of two and almost exactly similar. We have 7 ST50 instruments, just coming up to 7 years old - only problem ever is that the water temperature doesn't read right.
Being a cruising boat 4 of them are inside so protected, but the other 3 are at the helm and always uncovered except for the plastic caps. Boat is 7 years old, I doubt if it has been out of the water for more than 20 days total over its whole life and is exposed regularly to 60 knot plus winds and driving rain in its berth.
Of course I will find them all full of water next weekend now!!!!!
Not pushing Raymarine, there are a number of excellent manufacturers out there, but is strange how some have no problem. I have not followed up on this at all, but I have not heard of any general problems out here (New Zealand) with their nav instruments (except with the tller pilots).
John
dickh
8 Feb 2002
Suffolk
Am I the third who has had no problems with ST50 instruments? I've had my boat for 5 years now, they were fitted well before I got the boat, 2 instruments inside and 6 instruments in the cockpit but they are reasonably protected by the sprayhood. No problems to date apart from a new log impellor about 3 years ago - oh, and the fact I have to clean the impellor almost every time I go out, but I only bother on long trips now. No problem with the ST4000 Autohelm either. Until this post I thought they were great and would have recommend them to anyone(apart from the cost).
I always keep the caps on them when not in use, but one is showing slight crazing on the display when you see it at a certain angle.
<hr width=100% size=1>dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
pugwash
30 May 2001
SW London
Plese explain more
Don't understand your method. Would it relate to the leaky buttons on my ST2000 tiller pilot which I posted about the other day? I'm thinking of taping thick clear polythene over the buttons and display. Is there a better idea using plastic spray?
charles_reed
29 Jun 2001
Re: Ray Marine, Anatoly and Hey Kim have you seen
Forgive me aod, for saying it, but aren't you a little naive?
It's impossible to entirely waterproof electrical instruments which have a keyboard and if you did have them available you'd certainly not like the price.
Speak to a technician working for Simrad, Raymarine or B&G and they'll confirm.
With regard to the 4000 ST control head, it really needs to be mounted in a protected area. Mine is in the companionway and it's given sterling service for 11 years.
I've found a vast improvement in their customer care since Raytheon had their management buyout and became Raymarine. Mind you it was pretty dire before then.
Within normal commercial considerations, I've found their equipment the equal, if not better than their competitors.
I fear that water-ingress into keypad-controlled electronic instrumentation is a fact of life with which we all have to live - just as all vertical twins engines are inherently unbalanced.
PS I have another manufacturers' instrumentation on my boat and no commercial interest in Raymarine.
