Beneteau 21:7 shroud fixing
Colin Brown
1 Sep 2020
Hi, I have a slight ingress of water through ( I believe) the port shroud fixing. Removing the head lining in this area under the deck, reveals a stainless steel plate , irregularly shaped, with 2 nuts holding down the shroud deck fitting
Before proceeding to remove the nuts and pull the shroud plate out onto the deck , any advice/ previous experience welcome. I intend to re bed on the shrouds on Sika flex 291 or similar
