[3889]
What's the Spanish for 'why did you buy a Bavaria instead of a Moody?'
¿Por qué comprar un AWB en lugar de un MAB?
I don't understand this "light weight" argument. Light weight compared with what - a steel boat? As far as I can see, a 6 or 7 year old Bavaria 37 weighs 6.9 tonnes, whilst a Hallberg-Rassy 37 weighs 7.5 tonnes.
Well your figures are wrong, see the attached image. The HR378 is on the left and weighs 7500KGS and has a ballast ratio of 38.67% the BAV 37 (2007) weighs 5360kgs and has a ballast ratio of 33.21. So the Bavaria is longer, wider, has a higher centre of gravity and has a shorter keel. The differences in the way these two boats behave is profound.
I tried to provide you will a simple clear answer to your question and you dismissed it out of hand and it is quite clear that you don't understand what you are talking about and are not open minded enough to listen to the advice of others, advice YOU sought.
You will only learn the hard way.
Good luck.
FWIW a Starlight 35 has a balast ratio of 40%
Good luck.
Would help if you checked your facts. The data on the Bavaria you have quoted is WRONG - it is from the 2001 37, although the photo shows the later model.
pvb was correct (from the Bavaria brochure of 2007) Displacement 6900kg ballast 2000kg (29%) and draught (standard) 1.95m Hull length is the same, LWL is less and beam slightly more.
Faced with choice between a 1987 Moody and a 2007 Bavaria, I'd go for the Bavaria without hesitation. An 87 boat is going to be a constant maintenance issue; at least a 7 year old Bavaria should enable you to spend more time playing and less time mending. There's nothing inherently bad about Bavarias, they perhaps suffer from an inferior reputation fostered by ignorant critics. The boats are solid, well-built, and withstand heavy charter use easily.
20 years newer for £20K? How could you not go for the newer boat?
I can understand this sentiment and to a degree I agree with it. But, it is a bit too black and white. I have several times bought a boat of the age of that Bavaria only to find that obsolescence of boat equipment starts at year 10 or thereabouts. So you would be buying the Bav at just the time that it starts to need some expensive bits and pieces. And if you keep it for 10 years as you think possible, you will definitely be into the territory where things like engines need major work or replacement. .
One final comment. Depreciation. My guess is that you will lose more on the Bav but it is a guess.
As for boat quality, the Moody will be more heavily built with more solid woodwork ...
Sorry to keep mentioning this, but I don't understand the "heavily built" argument at all. Take off the ballast weight and the Moody 376 is 4870kg; take off the ballast weight and the Bavaria 37 is 4900kg - heavier than the Moody. Assuming their rigs, engines, etc, are similarly proportioned, in what way is the Moody "more heavily built"? If its woodwork is more substantial, it would seem that its hull must be less substantial.
Cut a hole in a Moody and then a Bavaria (I've done both) and you will see where the heavier build is. I took a core out of our cockpit coaming for an instrument and it's 18mm thick, the Bavaria I worked on had far less on the transom - which was cracked after a minor collision.
OK, so if the Moody has thicker fibreglass, its woodwork must be more lightly built than the Bavaria's.
If one item (regardless of what it si) weighs the same as another larger volume one, both without anything bolted on, don't you agree that one must have heavier layup/be thicker than the other?
Edit: It seems the Moody Owners' Association reckons the displacement of the 376 is only 7373kg which, less 2950kg ballast, gives a boat weight of 4423kg versus 4900kg for the Bavaria 37.
