1GM10 running issue under load. Help please!
bamboozle
9 Dec 2024
I wasn't thinking about the engine being worn out. I lost power because the head gasket went - not badly enough to stop it actually running but stopped it to achieve full revs. Turn the engine over with and without the decompressor. If there is no or little difference I would consider the head gasket as a suspect.
Did that and seems the same both ways. Thanks for sharing
The culprit could be the on engine filter. It's a mother effer to deal with and very easy to cross thread the knurled nut attaching the bowl to the filter and also very easy to nip the gasket that between those 2 parts. Also the bleed screws could be a bit mullered and not seating properly., both on the filter and the injector pump.
I eventually solved the air in and then went and bought a Beta 14 (slightly extreme solution) !
Good luck, you seem to be on the right lines.
Thanks for your reply. How did you solve the air leak in the end? The bowl nut seems to go on easily, not cross threaded and I put a new o ring on, but maybe it still leaks. I also thought replacing the nylon washer and copper washer on bleed screws could solve any leaks. I dont know what else to try really - I wonder if anyone has had any luck fitting a pressure gauge between certain points in the engine to try and find the leak. To confirm, would a simple air leak cause the issues im having? (max rev in neutral, poor performance in gear?)
pioneer
18 Jun 2012
Beckenham, Kent
i had 2 different situations, firstly the engine was "surging" kept wanting to develop power and then wouldn't. Fine out of gear. Solution was dirt in the lift pump diaphragm. The second was trapped air in the system caused by the spill pipe returning to the off engine filter so nowhere for any air to escape. It had to be back bled, not sure how that was done, as, in despair and time poor i got my favourite engineer to solve it and went sailing. When it re-occurred the spill pipe was re-routed to the main tank and the problem went away. Then i changed engines. I expect you've already do it but start at one end of the system and work towards the other, tedious but hopfully that'll find the ingress of air. Just a random thought but is the fuel tank level above the spill pipe return entry and is the spill pipe clear. might be worth a check.
chriscallender
30 May 2001
One trick I've used in the past is to temporarily put a section of clear tube in and look for bubbles. You could start with the return plumbing, if there is no bubbles there its probably all sound on the outbound side too (where the pump pulls a vacuum). I'm not convinced a pressure (or suction) guage would show much difference with/without a leak, well anyway I never tried it.
tillergirl
5 Nov 2002
West Mersea
"Did that and seems the same both ways. Thanks for sharing"
There are two ways of interpreting that: Do you mean that it is no harder to turn with the decompressor released. If so you need to look at the head.
Porthandbuoy
27 Apr 2003
The Gareloch
www.backbearing.com
If it starts okay then I'd be tempted to think the compression was okay. Worth checking the tappet clearances and make sure the decompression lever is fully disengaging before you start dismantling though.
Miniscule air leaks on the suction side of the lift pump can be a bugger to locate and cure. My solution was to paint all the joints with 'liquid whipping', some sort of rubbery paint used to stop rope ends fraying. Do it while the engine is running to suck the stuff into the leak. A bodge I know, but it cured the problem.
You mentioned "a touch of diesel bug". That's like saying "only a little bit pregnant". That slimy horrible stuff will clog a filter in no time. Cleaning the filters is no good, they need to be changed and biocide added to the tank.
The metal pipe running from the secondary filter to the injector pump. Check it for any dents. It's pretty small bore and any restriction there could limit rpm under load.
barryhall
3 Feb 2007
Leedstown
Hi All, I've tried to research this the best I can, but thought I'd start a new a thread incase someone might be able to help with my particular case.
I have a 1GM10 that starts and runs well (up to max rpms) in neutral / when not in gear, but as soon as its in gear under load it's unable to reach max revs and throttle response (especially mid range) is non existent. In gear the throttle responds quite well up to say 1200 rpm, then the throttle has no effect on revs until its almost pinned at full throttle - then the revs rise and settle around 2-2500. I understand that I should be able to get this engine up to 3600 rpm, cruising at 3400 or so. When applying more throttle, there is no change to exhaust fumes which makes me feel like its a fuel starvation issue not an overloading issue (overloading, dumping more fuel would make black smoke?). Generally there is no smoke from exhaust at all.
Things i've done so far -
- checked hull and prop, both are clean and free of debris. Prop turns easily by hand and is the original prop for the boat, so I dont think its overpropped. The boat has also performed fine before, reaching circa 6 knots.
- cleaned out both primary and secondary filters. There was some crud and water in secondary fuel filter that ive cleaned out now. Not sure if this might have caused damage further down the line in injector pump etc?
- Bled whole system multiple times using outboard motor hand pump. Only part im not sure ive bled properly is at the injector itself, do I need to bleed this with the engine is running? Engine has always started on the button straight away, so I feel system has been bled well previously.
- rigged up a fresh can of fuel straight into the lift pump to bypass the normal fuel tank, fuel lines, racor filter etc. Boat ran the same as it did when normal tank etc was connected, which makes me think that system is working fine. Next idea was to bypass the lift pump too and see if I have the same issue.
- Ive not checked the exhaust elbow just yet, but its on my list. Its only 2 years old, so I suspect it should be fine?
Wondering if anyone has had a similar issue and did you find the fault in the end? Thanks
It may be that you have already eliminated this but have you checked that the throttle linkage on the engine is actually going to full travel and it’s not a linkage problem?
38mess
9 Apr 2019
All over the shop
Good point.
In the summer my Perkins wouldn't rev over 1500 in gear, checked everything as you do. Turned out to be the cable clamp came loose in the morse control, it was just gripping the cable at low revs but slipping through the grip the further the lever was pushed forward.
bamboozle
9 Dec 2024
Did this stop the engine getting to full revs out of gear as well as under load?
bamboozle
9 Dec 2024
Ive already had the lift pump apart, cleaned it and all looks well. My return hose goes back to tank - Im going to check that its not blocked etc, but shouldnt have trapped air issue. Ive worked through the system alot already, but i guess the secondary filter set up could still be leaking, its just hard to confirm.
bamboozle
9 Dec 2024
Good point.
Ive checked all the hoses and clamps, but will check again, ive tightened everything I can see
bamboozle
9 Dec 2024
liquid whipping idea sounds good, will try that.
By a touch of diesel bug, I mean that I think it was starting to form / spread and I treated it quickly - sucked and ditched the fuel in tank and have changed filters since. Still a bit of grime in tank, that I need to get out. I think the lines from the tank to lift pump are okay though, as I rigged up a fresh fuel can straight to the lift pump and all symptoms remain the same - suggesting to me that all lines, main fuel tank, racor etc are all ok. The issue must then be from the lift pump and onwards. Ive already have lift pump apart and cleaned it, so next step was the secondary filter. I put new filter in and changed o rings, washers etc. I really want to check the line between the secondary filter and injector pump, but its a metal line, so wouldnt know how to check. As mentioned before, when bleeding injector pump screw when engine running I get alot of air bubbles that never clear, is this normal or should fuel spray out of here when engine on, screw cracked? Thanks
bamboozle
9 Dec 2024
I read that the injector pump can often create bubbles in the final line up to the injector (as in its normal for this) and so the return line can often have bubbles in it anyway? This may be incorrect, but just read on other forums multiple times. I'll try the clear pipe idea anyway and see
tillergirl
5 Nov 2002
West Mersea
Fine out of gear, reduced revs under load. At about half revs in gear it could not increase. There was enough compression to start the engine but I could see little different in the compression with and without the decompressor activated. I lifted the head and could see the gasket had been blowing. Clearly the 'blow' was small enough to accept moderate compression. I guess it would have got worse and eventually impossible to start. New gasket solved it. Starting was improved and back to full revs.
chriscallender
30 May 2001
That could be true. When I did this, air was getting in at the filter and it was pretty obvious, the bubbles in the return weren't minor. It was certainly much better when I fixed the leak but I don't really remember if there were tiny bubbles still remaining from the injector pump - it was a long time ago now. As far as I remember, mine needed PTFE tape on the BSP hose connectors that screwed in to the filter ports to fix it.
mickywillis
23 Mar 2007
Epsom,Surrey
I had a similar issue about 12 years ago with a 1GM10, I cant link to original post, but managed to find a copy of what was written at the time.
Took me 18 mths to get to the bottom of the issue, to the point I was about to buy a replacement engine? I'd done everything and more!! Hope it helps?
Many of you nice peeps on the forum have offered answers/solutions to my ongoing problems with my engine in my Westerly Pageant, Zara ( see http://www.ybw.com/forums/showthread.php?t=288148 for ongoing saga!!)
She was launched again in late March and during the winter, I had the injector rebuilt by Watsons Diesels and had the prop re-pitched by T Norris, in the hope that these may cure my problem.
When taken up Langstone Harbour for a test run 2 weeks ago, Zara felt worse than ever. Barely able to make 3 Kts, we struggled to get past the entrance of the harbour against the tide. In fact, we turned round and came back in to the mooring for fear of breaking down and having to sail onto mooring or get a tow back.
So this weekend I decided to change all the filters again, change the bleed screws, O rings and anything that would possibly let any air into the system. If this didn't cure the problem, I resolved myself to remove the cylinder head, check bore wear, reseat the valves and look for any problems due to loss of compression.
To gain better access to the engine filter ( the one bolted onto the rear of a Yanmar 1GM10) I decided to remove the whole assembly so I could renew the filter, O ring and the 2 bleed screws on the top of the housing. When I removed the aluminium bowl, I noticed that the paper element filter was crushed and slightly twisted. I had noticed this when I changed the filter in July, but put this down to the fact that I was using non genuine Yanmar filters and that they may be a little too long for the housing.
When I started to remove the bleed screws, I inverted the housing and looked onto the spigot where the filter pushes onto. Something didn't look right?
Inspection revealed the metal disc of an old filter had remained on the spigot. This was why the old filters had crushed and distorted slightly, but had been able to just about fit on the spigot. The act of tightening the filter housing securing ring pushed the new filter against the remaining disc, enough to form a seal and to not cause problems at times of minimal fuel demand. But once the lift pump tried to allow more fuel to the injection pump, air was being drawn into the system at the intersection where the 2 metal discs contacted. A previous test with a separate fuel tank also didn't highlight the problem as the filter is installed between the lift pump and the high pressure pump.
I removed the metal disc, refitted the new filter, bled the system and serviced the rest of the engine.
The little Yanmar now runs like it did when we first had her! It sounds smooth, powerful and strong, in fact I feel that all the other works carried out have given the boat a much greater turn of speed and pushes the hull up to design speed quite happily. The re-pitching of the prop seems to allow the motor to rev more freely, but I haven't had a chance to put my rev counter on the crank pulley to see what max revs are under full load. At no load on the jetty, the motor will now rev to 3800 RPM (previously 3200RPM) so it will be really interesting to see what she runs at at full bore, under load in gear.
Hopefully the pictures below will give an idea of what I found (this is a spare filter housing I have, not the one on the boat, but the disc and filter are the ones removed)
Interestingly enough, when the housing was fitted on the engine, the metal disc could not be seen due to the engine location within the boat and the obscured view afforded from the engine hatch and the cockpit access. Not only did I not spot it, but neither did the marine engineer who worked on the boat when we broke down in Ryde last year (not his fault as I say, it couldn't have been seen unless the housing was removed from the engine)
I service the motor each April when she goes into the water and I really do not remember seeing or removing the filter element without the metal disc on the top.
So a big thanks for all your suggestions and hopefully my problems and resolution may be able to help someone suffering a similar problem. I had checked all the usual (and suggested) points of possible air entry into the fuel lines, but no-one came up with this as a possible cause to the problem - perhaps this is a first?
bamboozle
9 Dec 2024
okay, i'll try again and will use some PTFE tape to seal. Would an air leak cause my symptoms anyway or would this cause random drops and surges in rpm? My rpms are quite steady, its just that in gear i can only rev about half as much as I can in neutral.
bamboozle
9 Dec 2024
Thanks for this, i'll check the filter housing again. My filters are not crushed or distorted though, so maybe I dont have this particular issue .
bamboozle
9 Dec 2024
I really hope its not the head gasket as the engine is only a few years old, albeit the previous owner didnt seem to care for it much. When your head gasket was blown, did you have a hard time starting the engine? Any noticeable change in exhaust smoke etc?
