MD2020 raw water pump removal question
essexsj
1 May 2018
Southend-on-Sea
Might be a novice question but should the engine oil be drained before attempting removal of raw water pump for the MD2029, or will there just be small amount of residual oil lubricating it whilst engine is running in normal operating conditions?
Thanks.
essexsj
1 May 2018
Southend-on-Sea
Thank you. Inherited this issue from my late father… not long before he passed away he told me of the problem he had trying to remove it. He gave up and was going to engage an engineer to do the job for him, but never got around to it before becoming ill.
xyachtdave
9 May 2009
MYC
Sorry to hear that. In my installation access from the left side of the engine isn't great, I removed the engine mount on that side to improve access.
I'd allow a morning to get it off, with a tea break around the time you feel like using a club hammer!
Neeves
20 Nov 2011
Sydney, Australia.
I don't recall the spanner sizes (and its late, dark and we are in strict lockdown - so I'm not venturing to the mooring).
But
As mentioned the locating nuts are a bugger. I used a long socket, a short socket and cut down spanners. First you need to 'crack' the nuts, then you need to turn them, but there is no room to get a spanner on them - hence the cut spanners.
There are only 4 - but I think xyachtdave is gilding the Lilly - it needs great patience
This is what you are aiming to find!
Image 5 A seawater pump, from the right, two mechanical seals (black) and the bearing.  The g...jpeg
I'm no expert, at all, but did remember to take some pictures. If I get it wrong - someone can add the details and corrections.
The geared end is 'in' engine, the right hand end takes the impeller. The two seals at the impeller end hold the raw water in and the other one 'secures' the oil. If I remember correctly (confirmation needed) - you need to take the gear off, gear puller, top of picture and then everything slides off (maybe you need the gear puller for the bearings as well. You will need to replace the 2 seals, they are not expensive - but buy them before you start. The shaft might be worn, at the seals, and then you might need a new shaft (I cannot advise). The housing that I have at the top of the picture - that's the engine end and 4 holes hold the studs (?) or bolts (don't recall) that are the bugger to remove.
If I'm right and you need to take the gear off, to access the bearings and seals, then you could use a wooden mallet with a wooden board with a hole in it (but a gear puller is more kind - and in every tool kit :) ).
It would be dead easy - on a work bench - I have to lie on top of the engine and remove mine 'up-side' down.
Along with the two seals buy some decent whisky - you can reward yourself when you finish.
Take care, stay safe
Jonathan
essexsj
1 May 2018
Southend-on-Sea
But
Jonathan
Thanks Jonathan, some great information there. My father had bought a complete new replacement pump and left it with a ‘sorry’ note for me ❤️??.
Myself and brother-in-law have recently replaced the engine mounts on my Moody 27, so quite used to extreme access methods, although this does seem to be rather more challenging.
yotter
3 Aug 2007
Me Inverkip, boat Kip in winter, Craobh in summer
The first time I removed the sea water pump on my MD2030 to change the oil seals, all went well apart from the 2 rear PITA nuts. All refitted, started engine, no water out of exhaust...... Then after some investigations removing coolant hoses and putting ends in buckets, found out the pump was going the wrong way, yes it is possible to fit it upside down. Was tempted to just swap the hoses, but removed the pump and refitted the correct way. I hope I will only do that once:)
Angus
Daydream believer
6 Oct 2012
Southminster, essex
I forget the exact details but I have had to remove the pump on my MD2020 twice. There is a a bolt that goes through & one has to access it from the rear. This is a job to get into place & takes ages turning the spanner. So I cut a slot in the end of it so a thin screw driver fitted the slot. Then I could fit the screw driver down the bolt hole & wind the end of the bolt from the front into place before having to use a spanner for the final tighten.
I forget which bolt & what way round, but have a look & work it out. You will find it well worth the couple of minutes cutting the slot. It needs a long thin screwdriver & one needs to run the bolt in & out of the hole prior to assembly so it turns nice & easy.
It will be there for the next time you have to do it which as well as having to put the bolt back you will find that you can get the bolt out in a few seconds once the initial tension has been released.
essexsj
1 May 2018
Southend-on-Sea
Got the water pump off at last - what a beast of a job!
Undid the two engine mount nuts and bolts from the bearer, and the two bolts from the engine block, pushed the unit back and wedged with a couple of slim screwdrivers, used a cut down 12mm open ended spanner to undo the rear thread bolts from the unit.
I presume I now need a gear puller to remove the old gear cog in order to add to the new one? or is there another method?
Neeves
20 Nov 2011
Sydney, Australia.
What is wrong with the existing gear?
From memory, which may well be flawed:
You should be able to remove the complete assembly relatively easily. (you need to remove the impeller first and then then whole lot pulls apart (in your picture the shaft with gear and seals lifts out vertically). You do not need a gear puller for this stage. I recall it just pulled apart - it might have needed a light tap (with a wooden mallet).
You do need a gear puller to remove the gear, or cogged wheel.
But once you have the shaft, seals and cogged wheel removed (as one unit) you could conceivably make up a bit of beefy hard wood with appropriately sized holes and resting the cog on the hard wood - hammer out the shaft - with a wooden (or appropriate) hammer). In your picture the shaft is hammered down.
But wait till someone adds to the thread as I have not dismantled for some years.
The major wear portion is the shaft, I believe, at the seals and that is how the unit leaks - through the wear of the shaft at the seals. I believe new shafts are expensive. I think the unit is supplied by Johnson and they might be the best source of a new shaft. But you seem to have a new gear (don't quite understand how the gear could be damaged, looks fine in your picture) and if you have sourced a gear then that source should be good for a shaft (if needed).
I don't know how you check the shaft - micrometer? But reassembly to check if it leaks seems a night mare - if you then need to pull it apart - again.
For such a small item it does cause untold heartache.
Jonathan
essexsj
1 May 2018
Southend-on-Sea
Jonathan
Hi Jonathan, thank you for reply.
I have a complete replacement water pump, however it does not come with a gear… hence the need to remove from old.
My father passed away so cannot ask why the need was to replace but there was a definite reason to do so.
Neeves
20 Nov 2011
Sydney, Australia.
Ah!
But there is nothing wrong with the gear, which was my interpretation. It appears your father had a problem with the pump, bought a new one (minus gear) and you are replacing the old pump with new and using the old gear on the new pump. Sounds straight forward to me now :)
As I said in my post No 11 - its actually very simple to take the gear off - so don't worry - but I simply don't remember which way round it came apart. I suspect your father had either an oil or water leak, or both (the shaft was worn) and decided to replace the lot.
Now - you have an old pump and the only bit you need is the gear (to add to the new pump). If you hear nothing useful (seems unlikely that no-one will offer help) then I'd have a look at the old pump you have taken off and check which is the obvious way to dismantle. I think that a few gentle taps with a wooden mallet for the impeller end of the shaft will remove the complete shaft assembly (because the gear will be in the way other wise). I am fairly sure the gear comes off the other way - hammer the thread apart of the shaft. I have a set of gear pullers (bought very cheap in HK 25 years ago) - but not much use to you as I am in Sydney
I'm surprised that the new pump did not come with assembly/disassembly instructions - but maybe they are in a pile of paperwork somewhere else.
From memory you need 2 new seals, unless they are on/in the new pump already
If you are not in a hurry (and no-one comes to your aid) - I have the workshop manual for the MD2020 - I can look there - but I will not be on our boat till early next week and will be unable to advise until mid week when I get back home.
You could try google - Johnson water pump MD2020
Jonathan
I had a quick look using google and there are a number of exploded drawings of the shaft assembly
Water pump kit for Volvo Penta MD2010 MD2020 MD2030 MD2040 D1-13 D1-20 3593659 | eBay
and it looks as if the shaft taper allows the gear to come off the threaded end - so in your photo the shaft is hammered or pushed down.
