Ship's Cat 73
While the engine runs fine for about 20 minutes, after that, steam begins to emit from the exhaust and the waterlock is too hot to touch . . . and I really mean TOO HOT. At that point the engine has to be shut down before it shuts itself down. With the engine running water only ever comes out of the exhaust in very weak spurts every 12 - 15 seconds and sometimes longer periods. (Other yachts I see are like a fireman's hose by comparison!)
Have already done all the usual checks - umpteen times.
Today I removed the 'final' pipe which delivers the 'spent' cooling water to the exhaust elbow.
The attached pic shows the port on the elbow and the 'hole' is around 12mm.
However, thinking it might be 'crudded up' I tried poking a small screwdriver in the hole, then tried poking a 2.5mm sheathed electrical wire -- none of these went in.
I stripped he sheathing off and twisted the remaining wires into a 1mm spike and only then was I able to penetrate the minuscule hole.
I can't believe that size of hole is seriously meant to cope with the amount of cooling water. When I see the size of that hole I can now begin to understand the very weak delivery of water out of the boat.
I'm tempted to dril a 'sensible sized' hole into the elbow but wouldn't want to go ahead with that until I know it would be safe???
As you look at the pic you won't be able to see the actual hole -- what looks like a 12mm hole is solid metal . . . is it possible that this elbow hasn't been cast properly?
