doris
I have been pondering this post. I absolutely agree in that I have yet to find a clutch that will hold the job halyard tension when going uphill with full sail and 20 something knots over the deck, so yes it does remain on the winch.My experience with furlers, which is probably a bit dated as I haven't actually sailed with one made after 2004, was that the halyard tension required for best windward performance in a decent breeze - i.e the most wind you had full sail out for - and the halyard tension required for an easy furl, were mutually exclusive.
And also, that even the best clutches struggle to hold the halyard tension you actually want in your foresail for upwind progress in a bit of breeze. There's a reason we leave the halyard on the winch upwind, and that's despite the fact that we have an extra cover stitched into the halyard at the point it goes through the clutch.
So easing the halyard slightly before furling just became SOP on dad's Dufour. Apart from anything else I didn't think it would do the sail a lot of good to have full halyard tension on it all the time.
For general cruising work, there's no right or wrong answer to where you want the halyard I think. I would absolutely favour bringing it back, but that's mostly because all my practiced techniques use that and I'm very familiar with it. And honestly I can't see a huge disadvantage, with the advantage that you can easily adjust under way. Having a split halyard, as Chiara does is a neat way of reducing the bulk of line in the cockpit whilst still giving you the ability to get the tail on the winch.
Also an absolute rule is to ease several inches of halyard before using the furler unless you want the bearings to only last a couple of outings.
I did think about all in/all out furling à la class 40s but £12k per furler that was seriously OTT. (That’s for the v smart Facnor system). And having the sail wardrobe to go through gears isn’t the sailing I have in mind. So have finished up going for Profurl on both the staysail and genoa. 10 yr warranties are v cool. By the way, they are now black, not that awful pale green! Probably more circumnavigations than any other furler.
How long the genoa sheaves last, well we’ll see. Normally about 4/5 seasons.
