Refueler
My new acquisition has a Jabsco bog ....
Due to Swedish guidelines - it has a rats nest of piping.
It is requested that bogs discharge to holding tanks and then HT is pumped to shore. But problem is that there very few pump out locations ! So its usual that the bog can be directed a) to tank, b) to sea.
That sounds simple enough. Until you add in the req't to pump tank to shore or to sea ...
My bog has a three way valve - position 1) closed, position 2) which directs bog content to the Mk V pump to pump out to sea, position 3) to the holding tank.
The sea outlet valve is downstream of the Mk V hand pump.
Now this sounds OK ... but in reality - the bog backfills ... why ? Because of the Jabsco system of the 'flick valve' on the pump body. Its very nice having one pump do IN and OUT .... but here it just fails ...
I assume it needs a good service ...
Once boat is lifted - we plan to do the unmentionable job of disconnecting pipes and try to create a better setup - plus service the Jabsco. The pipework is a mess - your hand comes away with nicks and scrapes using the system. as we need to close off all valves to try stop the backfill.
My other boat has the Royal Baby Blake ......... much simpler ... far better ... but maybe that's why it costs so much !!
