Daydream believer
Where are you going to get a hole saw to cut 8mm? Plus if you do get one, how is the pilot drill going to drill the centre that no other drill can touch?Get a proper solid carbide drill and drill it out - GBR Engineering Online Shop
Solid carbide will drill out taps, or a quality carbide burr and a dremel is the starter cheaper option
Masonry drills make very good metal drills if you sharpen the carbide insert a bit - they are a cheaper version than the solid carbide drills
A proper hole saw or better still a rotabroach cutter with a drill adapter will cut cast iron very easily
I tried a carbide milling cutter & others, in my mill, running at the correct speed & held firmly clamped etc on the fitting my friend had issues with & nothing not touched it. Drilling etc work hardens the already hard set screws & an allen key is pretty hard.
