petibonvm
Active Member
how do you beach a twin keel on a beach ? go up to touch, lower the front anchor go with the dinghy cast the rear anchor.
Thank you for your advice
Make sure you have surveyed your spot with the tide out in advance then motor towards shore until the keels dig in and leave the engine running to hold the boat in position until the tide goes out enough to be sure that you won't be turned around by the wind or the tide. Ive never needed to use an anchor.how do you beach a twin keel on a beach ? go up to touch, lower the front anchor go with the dinghy cast the rear anchor.
We too like more than an hours worth of tide fall, therefore potential rise, before we ground. The fear of being neaped is strongAs a long time owner of Bilge keel boats ... At High Tide time - I do not motor in till keels touch and let boat settle there. I back off till boat is afloat again ... drop bow anchor ... keep engine on low so boat is held between anchor and engine ... let tide settle boat. Stop engine when keels are on bottom ...
Why ? I do not wish to be stranded because of high pressure weather or other reasons of reduced high tide when wanting to depart. If tide has reduced a bit ... ie I am later than High Tide - then OK .. touch keels and stop .. but at HT time - no - back off giving you that bit of water extra just in case.
First, what you describe is beaching (which is different from drying out). The way I do it is to drop the stern anchor first which allows it to dig in as I approach the beach and keeps my stern pointing out to sea so the boat can't broach. Once I have landed, I drop my bow anchor, go ashore and walk the anchor up the beach a bit. This way, you don't need to use a dinghy.how do you beach a twin keel on a beach ? go up to touch, lower the front anchor go with the dinghy cast the rear anchor.
On the boats I've had, the skeg would get bounced going in astern, so always bow in for me, though that has meant we sleep heads to the bow in the V-berth.I preffered to reverse into position laying a bow anchor during or after beaching.
Can't get my head around the purpose of your bow anchor. If it never gets wet or am I reading it wrongOn the boats I've had, the skeg would get bounced going in astern, so always bow in for me, though that has meant we sleep heads to the bow in the V-berth.
On a falling tide, having made sure the next HW will allow me off*, I'll drop a stern kedge, and motor forward as slowly as the wind allows until we touch. Leave it in gear until we're well aground and pull the kedge line to dig the anchor in. Chill until I can get off with dry feet, walk the bow anchor out and dig it in by hand.
Before leaving, while still dry, take in the bow anchor and get ready. As the stern starts to lift, start the engine and go dead slow astern. When the boat starts to move, back into neutral (don't want the kedge line round the prop), and pull on the kedge line to bring the boat out. Retrieve the kedge, and off we go.
* A cautionary tale: Some years ago, a large yacht needed a spring tide to get on the Hardway scrubbing grid. Unfortunately, it was the top of springs, and the next tide wasn't as high. He was stuck there for a month, and much piss was taken. Fortunately, the next spring tide was a bit higher, and he was able to get off, but he never used the grid again
It's only needed if you're staying more than one tide.Can't get my head around the purpose of your bow anchor. If it never gets wet or am I reading it wrong
Won't disagree with many good posts. I preferred to beach our lift keeler at half tide.
At half tide in our area the tide goes at at an inch every minute. This means your boat dries rapidly in your intended place.
These precautions will protect you on the incoming tide as your boat floats free rapidly to the safety of your anchor in deep water and away from any potentially damaging breaking waves.
