DeFries
Comrade Red, I like to explore your 4 attachments in the first post of this tread. But they seem to be no longer available. Is is possible to post them again?
Pt2 - DIY Volvo Penta 2003 Instrument Panel
Following a whole tale of woe and frustration (see http://www.ybw.com/forums/showthread.php?406071-DIY-volvo-penta-instrument-panel), I decided not to spend the £200+ to get a replacement module, and with the help of circuit diagrams and some emails from the thread above, I set out to make my own, despite having not made any circuits since I was at school (a while ago).
All the components came from Maplins. No veroboard was in stock so I used plain board and pins.
I was unsure of the component wattages required so I hope I have erred on the side of caution.
The resistors are wire wound. I could not get a zenner diode of the right voltage (3.3v) at anything execpt low wattage, so I clustered 4 together in parallel.
I beefed up D1 as it is the main power into the circuit.
I took the original VP circuit diagram provided by CEPD, and added / modified it. My VP 2003 does not have glow plugs so there is one light redundant. I have added a circuit (the Aux circuit) to use that bulb for a switched (to negative) output from a cheap chinese ebay programmable temperature sensor which will get mounted on the exhaust.
My circuit diagram is below, along with the plan for the build, and a front and back photo of the finished board.
It tests out OK at home with a 12v bench supply.
It will get fitted to the boat tomorrow.
I am assuming I will not be able to recycle the 4 x bulb cluster as they are an integrl part of the broken module and it is all potted in, so I have instead gone with 4 x 4w BA9 bulbs and holders: I reckon the holders will fit somehow behind the coloured lens for the warning lamps. I will post some pics when this part is sorted.
So if you have a dodgy VP Control Panel, this is how to make your own and save several hundreds of pounds !! Enjoy.
Sadly I've lost themComrade Red, I like to explore your 4 attachments in the first post of this tread. But they seem to be no longer available. Is is possible to post them again?
Rehosted because I don't trust the forum software not to lose these again in the future;
