GarryF
Re the WiFi strength, I think that makes a lot of sense, so I will run a cable when I install - its not that bad now I know most of the "wire runs". It'll be very similar to my AIS setup, which is hard wired onto the NMEA 2K network for my main nav system with Garmin, but also has a WiFi connection so I can connect with my iPad if I have to run Imray Navigator in any emergency.My boat is 20m long and my router is about two thirds from the bow to the stern.
WiFi worked but was a bit flakey.
So I use a wired connection to my router - I had one near the bow anyway (for the Anchor Camera).
I understand that the RPi's WiFi isn't very strong so you might have problems with the connection.
That said, all the important detection and counting is done, locally, on the RPi so it shouldn't loose count but the web connection to it may get a bit flakey.
As with all projects like this (and fault finding) the key is to start with something that works and make changes accordingly.
I use that process all the time.
Re the testing, I powered everything down last night, and on power up this morning I rebooted the Raspberry, restarted chain.js and "happy days" it values had been written away.
Today I'm going to try and put a break in the code so I can step through it and get a better understanding - I believe that the F9 key allows the stepping, so just got to google how to set some break points. Hopefully by the time I get back out to the boat I'll have covered everything, so it should be a case of a simple install, but as we all know, that wont happen, and Im sure your last comment will come into play.
PS I am still walking around the house with a smile on my face
