ghostlymoron2
In a close encounter, how do you contact the other vessel? I do not have AIS and assume I'm not close enough to use bins.
In shipping world - its generally frowned upon to waste time trying to call up another ... that time should be used in avoidance manoeuvres.
Its also difficult to define which yacht someone is calling unless you are in location where very few yachts are ! Second - that many boats are not really listening to VHF ... it may be on - but unless a speaker is in cockpit - its unheard. Even DSC fails on this point.
Yes I am being serious ...
Agree with both! In general it is not a good idea to try and contact a ship; they will have taken action long before you can observe it, and you should follow the requirements of ColRegs and all should be well!'Vessel in position...... this is yacht.....'
Get AIS, at least receiver only. It isn’t expensive and it is really worthwhile, particularly for avoiding close encounters in the first place. I suspect nobody has ever regretted fitting an AIS receiver.In a close encounter, how do you contact the other vessel? I do not have AIS and assume I'm not close enough to use bins.
Agree - often referred to as "radio-assisted collision".Agree with both! In general it is not a good idea to try and contact a ship; they will have taken action long before you can observe it, and you should follow the requirements of ColRegs and all should be well!
However, I was once contacted by a commercial operator using @Pye_End's formula; I was heading south in the North Sea and the Amethyst Platform contacted me to warn me that I was likely to intrude on their exclusion zone. However, I realized pretty quickly that "Yacht heading South north of Amethyst Platform" was unlikely to be anyone else!
In agreement with @Refueler, I note that there are cases on record where the use of VHF has actually caused a collision that would have not happened if both ships had followed ColRegs. Indeed, if you follow the CHIRP digest, it's something that comes up relatively frequently; two ships agree to take action not in accord with ColRegs, there is a misunderstanding or a third party appears, and things go rapidly pear-shaped!
I think that the only time I MIGHT want to contact a ship would be to verify that they had seen me. But as I have both radar and AIS transponders, I'd hope I'm pretty obvious!Agree - often referred to as "radio-assisted collision".
I understand the temptation to call up and discuss/ask, but it is easy to end up causing confusion.
Assuming that they are looking at the screens.I think that the only time I MIGHT want to contact a ship would be to verify that they had seen me. But as I have both radar and AIS transponders, I'd hope I'm pretty obvious!
I suspect folk have regretted buying an AIS receiver, I know I kind of have.Get AIS, at least receiver only. It isn’t expensive and it is really worthwhile, particularly for avoiding close encounters in the first place. I suspect nobody has ever regretted fitting an AIS receiver.
When I was in the Baltic I noticed it was common for ships near busy TSS to call each other over VHF to clarify intentions.I think that the only time I MIGHT want to contact a ship would be to verify that they had seen me. But as I have both radar and AIS transponders, I'd hope I'm pretty obvious!
I wish I saved the money and put it towards a transmit/receive AIS unit! AIS really is brilliant.
I don't see the point in an AIS receiver only , if everyone is receiving and no-one transmitting then there's not much to receive!I suspect folk have regretted buying an AIS receiver, I know I kind of have.
