Koeketiene
In a close encounter, how do you contact the other vessel? I do not have AIS and assume I'm not close enough to use bins.
You're not close enough to use bins... How is that a close encounter?
Surely it depends on why you're trying to contact them, and how close you are? If at close quarters you think they haven't seen you a few blasts on the air horn might be more effective than "white vessel blah blah blah" on the radio.
My own experience of calling vessels is that "vessel on approximate heading x, this is the vessel at your bearing y, myname.. . " - they'll know their own heading, and giving them the bearing from their point of view is easier for them. Not protocol, but it does work, quickly. Reeling off coordinates does not, it's too verbose.
You're not close enough to use bins... How is that a close encounter?![]()
Without bins, the best assumptions for ship names are "No smoking" or "Safety first"In a close encounter, how do you contact the other vessel? I do not have AIS and assume I'm not close enough to use bins.
Without bins, the best assumptions for ship names are "No smoking" or "Safety first"![]()
AIS in the Solent is a bloody nuisance 99% of the time because you're always on a collision course with something (OK, slight exaggeration there, but you know what I mean).I don't see the point in an AIS receiver only , if everyone is receiving and no-one transmitting then there's not much to receive!
Initially I had an Rx engine, I soon realized how useful it was. It made me feel selfish in that I could see what others were up to but they couldn't see my details, that and doing longer passages spurred me into upgrading to a Transceiver.I suspect folk have regretted buying an AIS receiver, I know I kind of have.
I wish I saved the money and put it towards a transmit/receive AIS unit! AIS really is brilliant.
Ah but that makes it easy for the other half to track you also
My main planned use is offshore, eg crossing the Channel, when a CPA for crossing ships is helpful in working out how to thread between a steady line of big buggers, and to know when a big bugger has made a 3⁰ alteration of course to avoid me. The budget didn't run to AIS transmit, but better to see commercial vessels and know what they're doing, so I can prevent Colregs coming into play than having to guess, especially if fog comes in.
Ais is great for ships names. As stated above , using vhf for collision avoidance isn’t optimal but I’ve done it a couple of times when I wasn’t sure. Something like “ you this is me I’m in your 11 o’clock x miles do you have contact?” Normally does the trick and a couple of times has resulted in a thank you . It’s always been used in plenty of time so I could manoeuvre if required. Having the ships name makes things easy but without it I would use vessel type.
They are both cargo vessels though as opposed to yachts or fishing vessels.Interesting ... you say vessel type ...
So often I read articles .... hear people talking .... about xxx tanker at xxxx doing xxxxx ..... when in fact its not a tanker - but a Bulk Carrier .... totally different types and a Tanker OOW will not answer a call to a Bulk Carrier ... a Bulk Carrier OOW will not answer a call to a Tanker ...
Sorry but given the motion and difficulty in many sea conditions to read a ships name - I am with OP .....
This is not Hollywood where a clear stable image is seen out on the horizon !!
Possibly people are talking cross purposes here - a concern about a close encounter (depending on sizes of vessels) could be a predicted CPA of say 300m or less (remembering 100+m of that could be other bits of solid ship).How would you define a close encounter? 5NM, 2NM, 1NM, 05.NM, ... ?
Different skippers will have different comfort zones - some might start considering taking evasive action as soon as they see a contact on the horizon whilst others are quite comfortable sharing the same waters with a cargo vessel 1NM (or less) away.
And if you can't make out the name of a cargo vessel 1NM away (with bins) AIS won't save you but a visit to Specsavers is advisable.
The actual ship could still be 2-3 miles away.
Perhaps, but my experience is different.In my experience, on a small boat there are too many variables to take predicted CPA serious.
Your heading can change 10-15 degrees depending on the seastate.
When coming across merchantmen at sea remember that you are dealing with professionals working on an often busy bridge. The last thing they want/need is to be bothered by a small yacht.
Being as predictable as possible is often the best course of action and the best way to do that is to keep doing whatever it is you are doing.
Should the other vessel get closer than 1NM of your current position always remember that your yacht is far more manoeuvrable than his ship (aka: big ship has right of way).
If like the OP you don’t have AIS, how would you predict a CPA of 300m for a ship 2-3 miles away? Asking for a friend…Possibly people are talking cross purposes here - a concern about a close encounter (depending on sizes of vessels) could be a predicted CPA of say 300m or less (remembering 100+m of that could be other bits of solid ship).
