flaming
I think your interpretation of the COLREGs is correct. But..Colregs question please. Context is narrow channels (eg Hamble), good viz, vessels in sight of each other, no overtaking going on, close quarters risk of collision between a yacht under sail not motor (say a dinghy, or a 10-15m sailing vessel) and a powerboat of 30m. I'm asking here on s'butt mainly to get input from cruising sailors and dinghy sailors/racers.
- Colregs 18 contains what we often call the "power gives way to sail" rule which is: "Except where Rule... 9 ... otherwise require[s ] (a) A power-driven vessel underway shall keep out of the way of: ... (iv) a sailing vessel."
- Colregs 9b, which if applicable takes priority over rule 18, says "(b) A vessel of less than 20 metres in length or a sailing vessel shall not impede the passage of a vessel which can safely navigate only within a narrow channel or fairway"
- Colregs 9d says "(d) A vessel shall not cross a narrow channel or fairway if such crossing impedes the passage of a vessel which can safely navigate only within such channel or fairway."
- Colregs 8(f)(i) defines the shall-not-impede concept like this: "A vessel which, by any of these Rules, is required not to impede the passage ... of another vessel shall, when required by the circumstances of the case, take early action to allow sufficient sea room for the safe passage of the other vessel."
You then have the what-to-do rules:
- Colregs 16. Action by give way vessel. Every vessel which is directed to keep out of the way of another vessel shall, so far as possible, take early and substantial action to keep well clear
- Colregs 17. Action by stand on vessel. (a)(i) Where one of two vessels is to keep out of the way the other shall keep her course and speed.
FWIW, nothing in Hamble bye laws is relevant here - Colregs are not meaningfully altered by those bye laws.
I think it's clear from the above that Rule 9 trumps Rule 18 in these circumstances. Then what? Is it correct that the sailing vessel in my scenario is the give way vessel by virtue of 9b? Do sailors in general know/think/agree that? If navigating along the Hamble and there is a group of sailing dinghies, do they generally think are give way? I don't ever remember being taught that as a dinghy sailing/racing kid/teenager. Or is there some other interpretation or rule that I'm missing, that makes the motor boat the give way vessel?
Colregs are (imho, often stated in here on ybw) very imperfectly drafted, which is partly why I ask people's views on this
For a brief, and utterly inglorious, time I was part of the Foxer fleet in Hamble. The standing rule there was that when racing the fairway was out of bounds. And we assumed crossing the fairway to be akin to crossing a busy A-Road. It's honestly not a lot of fun to be in a tiny dinghy trying to cross back to the slipway when some of the larger MOBOs are coming in.
More normally I'm based in the Hamble, and so encounter dinghies in the river frequently. I'm not 30m, but they're really not an issue, and it's very rare that any actual racing takes place within the river, except in the "bay" opposite HRSC, well outside of the channel.
Generally I think the issues between MOBOs and dinghies stem from misunderstandings from both sides about the nature of their propulsion. In the Hamble I most often see this as MOBOs failing to understand that both themselves, and the moored boats, have a huge effect on the wind to a dinghy. If you're a 50 foot + flybridge MOBO you are taller than their mast and you cast a wind shadow that will remove all the wind from a dinghy. This can be tricky for non sailors to appreciate.
Experienced dinghy sailors will know this and anticipate, principally by going nowhere near you if they can help it. Less experienced sailors might not. Less experienced sailors also have far less "bandwidth" spare to look around, as so much more of their attention is focused on simply sailing the boat.
In addition, the wind on the Hamble, and especially in the channel, is nothing if not shifty, full of holes and generally unreliable. Especially when it's on the lighter side. So the exact conditions where large MOBOs have been out for a lovely blast around the solent, and beginner dinghy sailors have been out practicing. In the vicinity of the harbourmaster's office you often see dinghies nearly becalmed one minute, and moving well the next. So a dinghy may well set out across the fairway moving well, only to come to a near stop halfway across. Again, experienced dinghy sailors know where to look to anticipate this. Beginners don't.
Quoting the COLREGs when you're referring to a dinghy and a large MOBO may well make sense to an esteemed legal mind such as I understand you to be, but it doesn't change the physics when you've just removed the wind from the dinghy in front of you.
I fully understand that makes it stressful when bringing a large boat into somewhere like a Hamble, but expecting a neat legal framework to work seamlessly in a situation where you have wildly different experience levels, source of motive power and effect of one boat on another is perhaps a trifle optimistic.
