obmij
and most yachts use their motors 70% of the time anyway.
This is the inconvenient truth.
So why do most yachts use their engines so much?
I don't think you need to be young and bendy as such, but you do need to be motivated. The dream is to sail from anchorage to anchorage, steady breeze and fair tide - drop the hook, glass of wine with lunch and then off you sail back to your berth with maybe a well executed gybe or two to keep things interesting.
The reality, in the UK at least is that at least one of the elements will be against you most of the time you are on the water. It's a cliche but the wind is generally coming from the direction you would like to go - so a straight forward passage in a MB becomes a 200 tack ordeal with a VMG of 1 knot and an ETA of two hours after the pub shuts..unless you put the engine on.
Then there is the foul tide - might make a bit more progress with a few HP..or the need to punch through a confused sea state, much easier with the donk to lend a hand, and let's not mention tidal gates or weather windows.
Practicalities are not as straightforward either. Will you be sailing solo or two up with a partner of similar experience? If so, be aware that something as simple as putting a reef in can be an absolute pita on a small yacht in a bouncy sea-state. Actually, putting a TACK in can turn into an elemental struggle given a certain set of circumstances.
The above does not apply in a MB. You point and shoot and it is what it is. If you use your engine 70% of the time in a yacht then really what is the point? Your vessel will be slower, less efficient and less comfortable than a MB of similar length.
That is not to say that you should not go for it - but be aware that sailing is not all 'plain sailing' - and if you use your motor more than your sails you are probably better off with a motor boat (as are most sailors if we are honest)
