Changes to VHF licence
Black Sheep
13 Nov 2005
East coast, UK
Q: What does it mean for a VHF marine radio user?
A: Don't press the transmit button if anyone has climbed up to the top of your mast.
It really is that simple,
Unfortunately it isn't.
Why not?
The issue is to ensure you limit EM exposure to the public. Someone has already calculated with a 25W Marine transmission the safe distance is about 2 metres away from the aerial. Your aerial is at the top of your mast. Make sure nobody is up the mast before you press the PTT. Job done.
Apologies, I should have fleshed out my answer a bit... "no it isn't" on its own is a little bit trolly and I usually try not to do that.
First you're making a huge assumption - that the antenna is at the top of a mast. Mine isn't, even though I use sails. Motorboats also have them at a much lower height. It's quite likely that members of the public could be within a couple of metres of a such an antenna.
Even in the case of a mast-top aerial, there are occasions (in a lock; against a wharf; etc) that members of the public could be within the zone.
Second, you're ignoring the other part of the requirement - to demonstrate that your installation is compliant. Which means the set of calculations that came to 2m. And a set of operating procedures that clearly instruct the operator not to operate under any of the circumstances above when there is a member of public within the zone. (you may be as sceptical as I whether anyone will ever check this paperwork, but my understanding is that it will be a requirement)
Thirdly, you have said that your advice is to the "VHF marine radio user" (by which I assume you mean yachties with a SRC, limited to 25W). And that's fair enough within the limits, but many of us have other equipment on board (AIS transmitter, Radar, Radar transponder) and for those it is far from that simple.
Big caveat - I haven't ploughed my way through all the Ofcom bumf, so I might have some wrong ends of sticks here. But this is why we need some clearer guidance (I'm looking at you RYA! and you CA! And the magazines!)
Bilgediver
6 Jun 2001
Scotland
I have received an e-mail from the RCA regarding my "license". The only ones I have are a TV License and my Marine radio License and as the only one that transmits is my VHF Radio, I think it refers to that. I'm not a radio engineer so I'm reasonably unclear regarding its implications. My VHF is about 12 years old, it's a Cobra. My HH transmits @ ~ 3watts so it's exempt and my ship mounted one has an antenna at the top of my mast. It transmits (I think, the handbook has long gone) at 5 or 10Watts at full power. The guidance talks about transmitters licensed tom operate above 10W. Does this mean I can forget about it or is there something else I have to do?
The installed VHF radios we use normally transmit at 25 watts on high power so yes it will affect us in some way. The point of all this is to make all people on board aware that RF can harm under certain circumstances and we will possibly have to have warning signs on board to ensure people do not inadvertently expose them selves to RF beyond acceptable limits. There is a calculator where you can check the risks of your equipment. One risk could be some one working at the masthead while someone else has a long conversation on the VHF.
The notice from Ofcom suggests that our installations could be inspected for compliance so I presume this means to ensure warnings are in place. How many of us will be told off when this happens because we do not have our Call sign and MMSI displayed adjacent to the radio. :) . Tis a long time since the days of Bob B. inspecting radio installations around Central Scotland especially at marinas . A VHF antenna and no visible Radio Licence would result in a letter from Ofcom's predecessor.
Found it and now going to read it all on PC.
EMF calculator
Black Sheep
13 Nov 2005
East coast, UK
Well I will start to worry about it WHEN I see reports of random checks by Ofcom demanding yotties demonstrate their compliance with this new regulation.
Until then I will just go sailing.
That's probably a sensible response.
Nobody has to do anything now, anyway - we're still in the consultation stage.
Never Grumble
29 Sep 2019
England
You make a very good point, the fixed VHF yottie radios will all be about the same. The problem will be understanding the rest of it. Its even making me wonder if a push-pit mounted AIS aerial is still an option. Having paid membership for a couple of years, I think I might email the RYA and see if they can decipher it for me.
Reminds me of my days in the navy and man aloft procedures with keys and tallies.
Bilgediver
6 Jun 2001
Scotland
There is a lot to get through and the link seems to have failed at Ofcom so will need to search the site. The main concern for us is around the main VHF set which operates at 25 watts on full power. The minimum distance between members of the public and the transmitting antenna calculates at 1.6 metres. We have to ensure that no one is closer than this distance when transmitting at full power. This is not a problem on most yachts so long as the antenna is not close to the cockpit or no one has climbed the mast however it may be a problem on RIB's and motor boats and might be a concern for yacht clubs where "members of the public" drive and work on club boats. It seems we as licensed operators have to look after ourselves on our boats as long as every one else (the public) are kept safe.
As a matter of interest the public should be kept 0.71 M from a walkie talkie at full power (5W) and 0.32 M at low power (1W). If we are concerned for our selves we need to grow longer arms.
Input parameters
Transmitter power (EIRP)=
25​
Watts
Operating frequency=
150​
MHz
Reference levels from ICNIRP 1998 Guidelines
Reactive near-field zone=0.32m
Referencel level for power density=
2​
W/m^2
Calculated result
Separation distance R=
1.60​
m
st599
9 Jan 2006
Input parameters
25​
Watts
150​
MHz
2​
W/m^2
Calculated result
1.60​
m
Sorry but this is wrong. The EIRP transmitter power is not 25W.
You need to add in the antenna gain.
st599
9 Jan 2006
Transmitter Output Power25W
13.95dBW
Antenna Gain3dBd
5.15dBi
EIRP13.95 + 5.15dBW
19.1dBW
81.3W
Here's a basic example - it's a pain as the conversion to/from dB requires logarithms. (I haven't checked the antenna gain against a real world antenna you can buy., it'll be a bit less probably)
To do it properly you'd need to remove some cable loss and take account of the duty cycle (i.e. during a conversation, what percentage of time are you transmitting)
The 81.3 figure is what's needed by the Ofcom spreadsheet.
JumbleDuck
8 Aug 2013
SW Scotland
Sorry but this is wrong. The EIRP transmitter power is not 25W!
As far as I can see from their spreadsheet calculator, they are allowing for an antenna gain of 1.64 (ie 2.5 dB). That gives a 2m compliance distance for a masthead VHF transmitting continuously and 0.3m for a Class B AIS antenna transmitting for 26.6ms every 30s.
st599
9 Jan 2006
The 1.64 is the difference in gain between an ideal isotropic antenna (EIRP) and an ideal dipole antenna (ERP). Seems a bit OTT for Ofcom to be expecting people to do this.
syvictoria
12 Oct 2009
Europe
Whilst an unlikely/rare situation, I suppose that potentially a masthead VHF aerial may be an issue if moored alongside a wall with a big tidal range...
Bilgediver
6 Jun 2001
Scotland
They have this conversion figure in their calculation to arrive at the figure that is of interest to the public.
