RichardS
N/A
As a fellow engineer, i think you can get this done for under the 20k if you are willing to make up parts etc. If we had gone ahead with the purchase of that hull, then I would have put a300tdi land rover engine in it, sans turbo, cheap, easy to find parts for anywhere in the world. I would run freshwater, have hot running water and run an extra alternator, and maybe a generator on a dog clutch. You would also have basic hydraulics is you wanted it with the power steering motor, or upgrade to a bigger hydraulic motor. Mate engine to a marine gearbox and stern gear is easy. You will find a mast cheap or free somewhere if you trawl boatyards, along with lots of other bits.
Use the boat as a research and development opportunity, and have fun going against some of the perceived wisdom of the yacht world.
Engineers forever.
Isn't that a massively heavy 2.5L engine for a small boat?
For me the main stumbling block would be engineering in the heat exchanger to cool the engine coolant but I guess that an engineer with access to a full workshop and welding gear etc could knock something up.
Richard
