NormanB
That pdf does give me some ideas though, thanks Norman. Though I can't rule out small leaks elsewhere, the fuel flow is good all the way to the injector, so I need to focus on that. Unless I'm told otherwise, I'm fairly sure I need a torque wrench before I can start looking at the injectors themselves and glow plugs, and more than likely that job will require new gaskets too, so I'm trying what I can for now.
I would hold off taking out injectors just yet, as long as you are getting good flow which you can observe by backing off on the fuel union at the injector itself. I think the fact that you had an air locked injection pump would have ensured there was a no fuel situation at the injector(s).
Can you not get hold of another battery and a portable generator?
Double up on the engine start battery and give them a good charge up, cranking the donk sucks the life out of the battery fast.
