ghostlymoron
My pals boat had a BMC 1.5, it was always a pig to start. He eventually fitted a Thermostart which helped but was a bit scary.
I am confused. If he has sprayed WD40 directly in to the intake then it should have fired irrespective of whether the injection system is working. Reading his posts, his knowledge of diesels is not that good, we are not able to see the big picture and so there are other things to take in to account. Is it cranking fast enough for example? etc etc.I agree that it seems very unlikely. The only reason I have suggested it is that I have started dozens of petrol/diesel/2T/4T engines with fuelling problems over the years using a squirt of fuel directly into the air intake, often using a hairdryer, and the engine nearly always starts ..... if only for a quick frenetic burst.
If the engine is petrol and there is no frenetic burst then I know it's probably an ignition problem. If the engine is diesel and there's no burst...... then what?
Richard
"reckon your fuel tank is 'leaping' and this will need to be addressed somehow,"
I've not encountered this term before do you mean leaking?
Sorry I missed that first time around. My bad.As mentioned before, the fuel tank was cleaned. But I have decided to start from the beginning again. Fuel filters taken apart and put back together, there was a twist in the main filter upper seal. Inspected the tank again, few black spots in there, must gave come back in to the tank from somewhere as it was clean. Both fuel filters only a week old and were changed after I cleaned everything.
The flexible return line from the head of the main filter to the tank was very brittle and cracked when I removed it, and although I noticed no fuel in the area, there could have been a crack there.
The lift pump seemed to have some air in the upper half as not much fuel came out when I removed the cap relative to the volume. I'm replacing the worn rubber seal with an aluminium one from the old lift pump I found onboard.
I had an impossible starting issue with this engine at sea. I traced the fault to the non return valve in the lift pump. I discovered this by blowing through each end with just my breath. The air was stopped each way. The ball that makes the seal was is held open by a spring, the spring had rusted and broken up allowing the ball to seat both ways. I replaced the spring from a Biro pen and it worked, engine started.
Apologies if this is errelecant but I have just read a few posts in the thread. On a phone with a small screen and travelling.
Good luck.
Oh, and I should mention that the wd40 can is only 1/4 full, so it may not have enough output to induce a firing if, as it seems, there is almost no fuel flow.
Thanks for replies. The seacock was shut during the 10 months, but open now.
Glow plugs drawing power when activated, though they aren't needed here.
Every single line individually removed and cleaned. A good squirt of fuel comes through at all stages of bleeding, and through all lines, except the high pressure lines.
So, the injector gause? Anything to watch out for when I start that job?
I did exactly the same thing, as you see if you check my original post. I even found old bits of the spring inside the injector union today, sobut don't forget to have a look there!
