And probably a lot more if the bottom is dirty.2600 hp, so the rule of thumb says 260 gallons per hour, 29 knots. Not as bad as I’d have guessed, but so far beyond my pay grade it might as well be powered by a Saturn V.
Indeed.This is a nice motor yacht if you can afford it. The Med is full of these type of yachts and only a very small minority are Russian oligarchs.
I guess that Saturn V is about the same mpg. It carries around 600,000 gallons of fuel (not counting oxidizer, to be comparable). It does around 600,000 miles to the moon and back and a few times round the moon. So, it's about a mile a gallon - much the same!2600 hp, so the rule of thumb says 260 gallons per hour, 29 knots. Not as bad as I’d have guessed, but so far beyond my pay grade it might as well be powered by a Saturn V.
Going from #2 the Sunseeker would be doing +/- 9 gallons per mile, but maybe a nought slipped in somewhere.I guess that Saturn V is about the same mpg. It carries around 600,000 gallons of fuel (not counting oxidizer, to be comparable). It does around 600,000 miles to the moon and back and a few times round the moon. So, it's about a mile a gallon - much the same!
Duh! Missed a 0. So, actually, it's cheaper to run a Saturn V!Going from #2 the Sunseeker would be doing +/- 9 gallons per mile, but maybe a nought slipped in somewhere.
The capital cost and once only use stings a bit though.Duh! Missed a 0. So, actually, it's cheaper to run a Saturn V!
If its not a toy I don't want to it ?For that sort of money I'd have a Nordhavn 96 which is a proper boat and not a toy...
I thought that the rule of thumb is one litre per hour per ten hp, not one gallon.2600 hp, so the rule of thumb says 260 gallons per hour, 29 knots. Not as bad as I’d have guessed, but so far beyond my pay grade it might as well be powered by a Saturn V.
That's unlikely, Saturn V 1st stage burnt ~12 tonnes a second; RP1 is near enough paraffin but LOX is quite pricey.Duh! Missed a 0. So, actually, it's cheaper to run a Saturn V!
I didn't count oxidizer; if I did I'd have to work out an equivalent for atmospheric oxygen. And I took the fuel volumes from a technical account, so they're about right. Yes, it burnt a lot, but not for very long!That's unlikely, Saturn V 1st stage burnt ~12 tonnes a second; RP1 is near enough paraffin but LOX is quite pricey.
So... around two gallons per mileI thought that the rule of thumb is one litre per hour per ten hp, not one gallon.
that works for my MD2020 which cruising at about 70% of peak revs uses approx two liters an hour.
