makka64
I feared as much.My first thought would be a new engine needed In there.
I think he knows what the problem is - hence the rapid drop in price over a couple of weeks. The mooring fees are 244pcm, just to eat into the pocket a bit more.Is it just me or do the engine bearers look a bit strange? That plate on which the engine is mounted looks to be bowed, so I wonder of the knocking noise reported by the owner is caused by a misaligned prop shaft?
I considered an outboard. It would be a good alternative. When you can pick a decent secondhand Hurley up for 3-4k I don't see the benefit of throwing cash at this.The Vire is a very simple two stroke engine and given that spares are available, if you've ever worked on a BSA Bantam, it shouldn't give you any trouble fixing anything. That said, this one looks to have a Ciba Dyanstart from which I would run screaming. My geriatric Bond 3-wheeler had one back in the late 60's and I ended up fitting it with a kickstarter. You don't have room for one BTW and the old Bond did at least have a basic Villiars bike engine and gearbox. You would have difficulty finding a replacement engine and gearbox as the 1GM and 1GM10 seem to have been discontinued and anyway it's not a job for a tyro amateur mechanic. An outboard on a bracket would certainly serve but you's be looking at best part of a grand even for a second hand one.
If you're looking for a hobby, go for it, by all means. They are generally sound wee boats and a touch of epoxy and glass wouldn't break you bank. If you want just to go sailing, get something more together.
It is slightly bijou lol.The H22 had an outboard well as standard and came with a plug for it if not used.
Having owned one many years ago I would get something a bit bigger.
I agree with you totally. I said it was too much of a risk, They are not that expensive to find in good condition and there's no justification in throwing money at it to make it into something that we can buy which doesn't need work.Any boat of this age needing major engine works and a new interior is a money pit. Avoid if your good lady isn’t one to fix or finance these things.
Completely agree. I just commented much the same.Here's one for just under £4k. Maybe it will sell for less:
Hurley - 22 in Cheshire, North West | Boats and Outboards
So my question would be, if you were given the £650 one for free, and spent £4k on it, would it get you to the condition that the more expensive boat is in now? My guess would be no, but it's purely a guess.
To someone you don't likeIt should be given away
