jamie N
With respect to the OP, all of us are possibly reminded of never letting the boat take you anywhere that your brain didn't get to 5 minutes earlier.
….. says the user named PESSIMISTAfraid I have to agree with others. Your responsibility and yours alone to make the decision to go. Always difficult to pull out, especially when there are external pressures to go. We've all been there and all cocked it up. Think of boating as staggering from one cockup to the next. FWIW our boat name is Snafu II..........?
Not sure I agree, we lock out all the time currently, always get 2 lines dropped, stern one 1st."My question is it normal to have only one line thrown down to the boat when going tying up in a lock, and thrown to bow rather than the stern when a wind of 32Knots was blowing directly from that direction?"
Yes, it is perfectly adequate to have just one line thrown … how many hands do you think the keeper has?
No, it’s not normal to throw it to the leeward end of the boat.
I‘ve never been in a lock where the keeper didn’t understand the effect of the wind on a boat.
Where was your wife standing when you entered the lock with the wind behind you?
I‘m guessing not at the stern where you should have briefed her to be. Otherwise how could he have thrown the line to her at the bow?
Sorry, it sounds 100% like skipper error to me unless by some chance the keeper was standing right at the leeward end of the lock forcing you to motor up to the gate and your wife to scramble forward.
A position you would surely have noticed before you entered the lock and made at least an attempt to reverse away.
Yes, that’s excatly the spirit. Even if the damage is worse it’s to a boat and not people.Just one thing to add:
It wasn't a disaster, just an incident. No one got hurt and the boat's still afloat, if with some cosmetic damage.
We had a group cruise to Shotley this year & some of the boats made a right mess of the lock entry with wind up the chuff. A couple getting stuck 45 degrees across the lock.To be clear - the method is:
1. Get a line from a cleat on your boat (midships or bow) to a strongpoint on the shore behind the middle of your boat.
2. Motor gently forwards steering to push the bow away from the dock (and the stern in towards it)
3. Once the side of the boat is resting against the dock, adjust the throttle and rudder angle to hold the stern in while you put on more lines at your leisure.
We had a group cruise to Shotley this year & some of the boats made a right mess of the lock entry with wind up the chuff. A couple getting stuck 45 degrees across the lock.It was all discussed over beer & wine in the cockpit of one of the boats. I had taken pictures of the antics which created some mirth, followed by serious discussion.
It was generally agreed that tying the bow was NOT the right solution . The 2 that did it the best tied the stern & motored gently against the lines. The bow then stayed in & could be secured afterwards. With all due respect I feel that with a modern AWB that method you describe is not suitable. On my boat, a spring line does not hold the stern in, regardless of what I do with the rudder. Prop wash decides if the stern goes in or out. It did not work for a Centaur either.
But to each his own & everyone has to find a system that works best for them as each boat is different. having found it then stick to it & disregard the armchair sailors.
Not this week, anyway. Next week, who knows whose turn it is to provide the entertainment?It does however provide entertainment for adjacent boaters, who of course would never allow such a situation to develop.
Does the lock at Grimsby have chains at intervals hanging down its sides around which a line can be passed, or is one entirely dependent on the lock keeper knowing what needs to be done to secure the boat safely? Or if he doesn't know, at least his being willing to do what he is asked.
Does not happen. The bow is thinner than the rest of the boat and, therefore, any foreward motion pulling on the bow rope automatically pulls the bow in & the stern out. Regardless of rudder. The harder one motors to get authority of water movement over the rudder the more the bow pulls in & that more the stern pulls out.I think I may have been misunderstood - the bow spring doesn't hold the stern in. The bow (I prefer midships) spring led aft on the dock stops the boat going forwards and pulls the bow towards the dock as you motor forwards; the prop wash goes over the rudder, if you try to steer the bow *away* from the dock, the propwash over the rudder will push the stern sideways against the dock.
I would love an armchair on my ketch, but my family who lives on board with me would object, and it would probably be impractical on the long ocean crossings.![]()
You can say that again. I heard a yacht calling repeatedly to the lock keeper & he just ignored him. On my first visit, he made the other yacht yacht & myself wait an 90 mins to go through, when there was ample water. He just kept leaving the gates open & letting wind farm boats in even though he could have let us go through in the intervals between the windfarm boats arrivals.They don't seem to be sympathetic to pleasure craft .
If using just one line, plus engine and rudder, to hold a boat parallel with a wall, it will only work satisfactorily if attached to a cleat or other strong point amidships. The boat will then pivot about its widest part, which is attached to the wall, with the engine and rudder pushing the stern in and hence the bow will swing out. This will work better on older designs of yacht, where the widest part is amidships, but is a little more difficult on modern "wedge-shaped" designs where more engine revs are required, or the line should be attached a little further aft. The only way I can logically see it working with a line secured at the bow is with a long straight type of hull, such as a narrowboat. Speaking of which; last night I saw on tv the spectacle of Gyles Brandreth running along a dock, hanging onto the bowline of a narrowboat, instead of securing it to a cleat?If you were using your engine and rudder to hold the stern against the side in the manner I described, you should have stayed in forward gear. You must have switched to reverse for it to get jammed there - why did you do that? It also sounds like your crew was holding onto the line instead of getting it onto a cleat on the boat - this is never a good idea except on tiny boats.
I suffered a gear cable failure when docking once, the scene ended with my bow in the cockpit of a visiting German boat, and their ensign pole snapped, with the flagging hanging limply in the water. It was not my finest hour. Ever since that moment, I have always checked I can get fwd and reverse gear before: lifting the anchor, dropping the anchor, leaving a berth, entering a harbour, leaving a mooring, picking up a mooring. I also check the rudder movement - I once had to stop the crew in the middle of letting the mooring go when I discovered the rudder was jammed. It turned out to be jammed with hard growth from sitting in quarantine for 10 days!
