jwilson
Since near new my Yanmar 3YM30 in a Sun Odyssey 35 has occasionally overheated at high revs. It was an early build engine and has had the later larger heat exchanger fitted under warranty.
The power range at which this overheating occurs is steadily increasing. At first it was only 3000 rpm plus that would cause it (max revs are 3400) and the boat will reach this revs giving about 7.8 knots, so is probably not overpropped. Now it is consistently overheating after a period at 2900 and on one occasion after an hour at 2500. It's not just the alarm, the engine is overheating.
As I regard cruising revs to be 2400-2900 - if the engine is on it's because you want to get somewhere - this is unacceptable. This rev range translates to around 5 - 6.5 knots.
In the last ten days with the assistance of a Yanmar service agent engineer I have had a complete new raw water pump fitted, a new temperature sensor, and the heat exchanger insides look clean. Also tested the engine with the thermostat removed. Still overheats given high power running, though lots of water is clearly circulating and coming out of the exhaust.
I suspect that others with this engine have the same problem but may not know it, as they rarely run their engines hard enough.
The engine manufacturers UK distributors told me at last years Southampton Boat Show that they do not know of any overheating problems with this engine. As they paid for the heat exchanger to be changed on mine and at least two others I know of, this is obviously not true, but they stuck to their story that no-one else had a problem.
If you have a 3YM30 that overheats, please PM me.
If you have a 3YM30 that has never overheated, but only ever run at 1800-2500 rpm, consider giving it a good 10-15 minute run at full throttle and see what happens, then PM me.
If you worry about giving your engine a few revs, ask a diesel engineer, who will probably tell you that diesels like hard work. In Hallberg-Rassy's manuals they actually say "......More engines are damaged by slow running and by rust caused from poor winterising at lay up than overloading or due to many operating hours."
If I am the only person with a Yanmar 3YM30 that persistently overheats I will have to find an answer myself. I think however this may not be the case.
Of course if you have a solution, please PM me - but don't just suggest I change the impeller! I've changed a lot more than that!
