franksingleton
I use windfinder - but as has been said above, the basic data is the same.
However, you should always look at a grib file as well - as this will give a good impression as to what is going on (particularly if you can animated it over a period of 48h or so).
Windfinder is based on the GFS. If the GFS gets it wrong, so will Windfinder. XCWeather is the GFS.
You really cannot look at specific grid points. You have always to look at the overall pattern. I say again, any model can only define weather on a scale of about 4 or 5 grid lengths. For the GFS and the UK Unified model, that is about 100 to 15o km. For Windfinder, it is about 50 to 60 km. For ECMWF, it is a little less than Windfinder.
However, like all models that are not run by national weather services, Windfinder starts with no detailed data. In the Med, http://212.175.180.126/DENIZ/DTS/sea.php should be the best. It is the ECMWF model that starts with a detailed analysis and uses what is probably the most advanced of all.
Outside the Med, I use the GFS. For small detail, if I really needed it, I would use one of the national weather service sites. In practice, I look closely at GMDSS forecasts. I monitor those continually together with the GFS to 8 days ahead.
